i understand how to tune my carburetor... and the problem isn't my condenser, compression, plug, gap, etc ether. the problem is that my bing leaks badly and i've done about everything that could be done to fix it (yes, i read the wiki on fixing a wiki leak). my moped runs great, it's just that i don't like leaking fuel from my carburetors bowl onto the engine. perhaps i should've clarified what my bing's been doing before exclaiming how terrible it is with no explanation...
i've replaced the bowl, gasket, float, float needle, my air filter, my fuel filter, my fuel line, my petcock, spark plug, ive derusted my tank, ive lined my gas tank, i clean my carb every 3 weeks or so, i tune it every time i start it, i've checked to make sure the float sits level, ive checked for knicks and scratches, i could go on. i've even bought a used bing from a friend and swapped the old parts from that into mine just to see if anything was wrong and it continues to leak. in all, i'm just not having the best experience with bing carburetors and haven't heard many other good experiences from other people either and don't feel like spending the money on another one that'll likely do the same thing or just continue to be a pain. a friend warned me a while ago to check out something different and i'm beginning to see what he meant.
i've heard and read great things about dellorto carbs from friends and on mopedarmy but wanted a second opinion and wasn't sure if size was an issue, which i understand now. especially regarding the intake, due to possible clearance issues since my moped wasn't designed for something other than a bing. so thanks, mop rider. i'll definitely take you up on that if you have an intake that'll clear well. i'll message you. (edited)
