Re: I don't get it....
Flagrant - /
Likely the reason the points quit opening is that the rub block on the points assmbly wore down from the cam on it. Might be good to get new points but in either case put a dab of grease on the cam so that as it turns that grease gets deposited on the leading edge of the points rub block so it doesn't wear so much
