Re: flat reed motor mounts
Yes, box that in, its going to have a lot of stress! Do you have a picture of how the motor bolt is hooked to your mount? I can't help but think that you need a more robust mount. This is sleek but I'm curious of its functionality. All motor/street vibrations will go through that small amount of steel.
You will also probably quickly find you need that rear stabilizer. The rubber-mounted front likes to wiggle, and with nothing holding the back in place it can feel funny through turns.
Anyhow, good job! Keep us posted on how it holds up.
  flat reed motor mountsTopic by: Spencer Jacobson Spencer Jacobson 10/11/11 03:26PM
  Re: flat reed motor mountsRe: Sidney Delicious Sidney Delicious 10/13/11 04:00PM
  Re: flat reed motor mountsRe: bob mcmaster bob mcmaster 10/13/11 05:27PM
  Re: flat reed motor mountsRe: cj cj cj cj 10/13/11 06:22PM
  Re: flat reed motor mountsRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 10/13/11 09:07PM
  Re: flat reed motor mountsRe: Sidney Delicious Sidney Delicious 10/13/11 11:24PM
  Re: flat reed motor mountsRe: Ryan N. Ryan N. 10/13/11 11:32PM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 10/14/11 12:44AM
  Re: flat reed motor mountsRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 10/14/11 12:36PM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 10/14/11 05:26PM
  Re: flat reed motor mountsRe: cj cj cj cj 10/14/11 05:49PM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 10/16/11 01:54AM
  Re: flat reed motor mountsRe: Dan O Dan O 10/16/11 05:07PM
  Re: flat reed motor mountsRe: JJ Herzog JJ Herzog 10/18/11 01:14AM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 10/24/11 07:07AM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 10/27/11 09:32AM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 10/27/11 10:51AM
  Re: flat reed motor mountsRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 10/27/11 01:43PM
  Re: flat reed motor mountsRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 10/27/11 01:50PM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 10/27/11 05:57PM
  Re: flat reed motor mountsRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 10/27/11 07:47PM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 10/28/11 07:00AM
  Re: flat reed motor mountsRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 10/28/11 11:20AM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 11/03/11 04:50PM
  Re: flat reed motor mountsRe: Nick Amos Nick Amos 11/03/11 05:09PM
  Re: flat reed motor mountsRe: derbeez ryderz derbeez ryderz 11/03/11 05:39PM
  Re: flat reed motor mountsRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 11/03/11 07:17PM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 11/03/11 08:51PM
  Re: flat reed motor mountsRe: Andy Haldeman Andy Haldeman 11/03/11 09:01PM
  Re: flat reed motor mountsRe: . (Nick) . (Nick) 12/28/11 02:27PM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 12/28/11 03:33PM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 12/28/11 08:38PM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 12/29/11 12:52AM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 01/07/12 08:23AM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 01/09/12 02:07AM
  Re: flat reed motor mountsRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 01/09/12 09:17AM
  Re: flat reed motor mountsRe: mit mortso mit mortso 05/27/14 12:32PM
  Re: flat reed motor mountsRe: Cole Doubt Cole Doubt 05/27/14 02:01PM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 05/28/14 09:00AM
  Re: flat reed motor mountsRe: mit mortso mit mortso 05/28/14 02:17PM
  Re: flat reed motor mountsRe: Chris Toth Chris Toth 05/28/14 04:07PM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 05/28/14 07:49PM
  Re: flat reed motor mountsRe: Richard Schwartz Richard Schwartz 05/28/14 09:46PM
  Re: flat reed motor mountsRe: mit mortso mit mortso 05/29/14 02:09AM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 05/29/14 07:32AM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 05/29/14 07:40AM
  Re: flat reed motor mountsRe: Chris Toth Chris Toth 05/29/14 10:26AM
  Re: flat reed motor mountsRe: Richard Schwartz Richard Schwartz 05/29/14 07:01PM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 05/29/14 11:38PM
  Re: flat reed motor mountsRe: Cole Doubt Cole Doubt 05/30/14 02:13AM
  Re: flat reed motor mountsRe: mit mortso mit mortso 05/31/14 04:04PM
