Re: flat reed motor mounts
Here are a few showing more of what I did. Note this is the rough draft, in mockup, so bolts are loose. It is a little sketch looking, but so far is solid. I'll take more pictures when I tear it down for inspection. Everything is quite compact on the pedal side and all is a very tight fit. The upper bolt utilizes the existing bolt hole on from the factory e/za50 mount, while the lower has an individual bolt on either side, mounted to a bracket which has 2 additional bolts connecting either bracket through the case. Finding those long m8 bolts locally was a bitch. Better spacers are still in the works. When mounted/torqued everything lined up nice and square (unlike in the photo).
Are you using a flat reed or revolution motor? Although both are similar, the revolution cases are longer necessitating more cutting. Rufus also cut/ground his cases but I don't know how much specifically.
  flat reed motor mountsTopic by: Spencer Jacobson Spencer Jacobson 10/11/11 03:26PM
  Re: flat reed motor mountsRe: Sidney Delicious Sidney Delicious 10/13/11 04:00PM
  Re: flat reed motor mountsRe: bob mcmaster bob mcmaster 10/13/11 05:27PM
  Re: flat reed motor mountsRe: cj cj cj cj 10/13/11 06:22PM
  Re: flat reed motor mountsRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 10/13/11 09:07PM
  Re: flat reed motor mountsRe: Sidney Delicious Sidney Delicious 10/13/11 11:24PM
  Re: flat reed motor mountsRe: Ryan N. Ryan N. 10/13/11 11:32PM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 10/14/11 12:44AM
  Re: flat reed motor mountsRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 10/14/11 12:36PM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 10/14/11 05:26PM
  Re: flat reed motor mountsRe: cj cj cj cj 10/14/11 05:49PM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 10/16/11 01:54AM
  Re: flat reed motor mountsRe: Dan O Dan O 10/16/11 05:07PM
  Re: flat reed motor mountsRe: JJ Herzog JJ Herzog 10/18/11 01:14AM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 10/24/11 07:07AM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 10/27/11 09:32AM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 10/27/11 10:51AM
  Re: flat reed motor mountsRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 10/27/11 01:43PM
  Re: flat reed motor mountsRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 10/27/11 01:50PM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 10/27/11 05:57PM
  Re: flat reed motor mountsRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 10/27/11 07:47PM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 10/28/11 07:00AM
  Re: flat reed motor mountsRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 10/28/11 11:20AM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 11/03/11 04:50PM
  Re: flat reed motor mountsRe: Nick Amos Nick Amos 11/03/11 05:09PM
  Re: flat reed motor mountsRe: derbeez ryderz derbeez ryderz 11/03/11 05:39PM
  Re: flat reed motor mountsRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 11/03/11 07:17PM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 11/03/11 08:51PM
  Re: flat reed motor mountsRe: Andy Haldeman Andy Haldeman 11/03/11 09:01PM
  Re: flat reed motor mountsRe: . (Nick) . (Nick) 12/28/11 02:27PM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 12/28/11 03:33PM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 12/28/11 08:38PM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 12/29/11 12:52AM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 01/07/12 08:23AM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 01/09/12 02:07AM
  Re: flat reed motor mountsRe: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang 01/09/12 09:17AM
  Re: flat reed motor mountsRe: mit mortso mit mortso 05/27/14 12:32PM
  Re: flat reed motor mountsRe: Cole Doubt Cole Doubt 05/27/14 02:01PM
  Re: flat reed motor mountsRe: Spencer Jacobson Spencer Jacobson 05/28/14 09:00AM
  Re: flat reed motor mountsRe: mit mortso mit mortso 05/28/14 02:17PM
  Re: flat reed motor mountsRe: Chris Toth Chris Toth 05/28/14 04:07PM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 05/28/14 07:49PM
  Re: flat reed motor mountsRe: Richard Schwartz Richard Schwartz 05/28/14 09:46PM
  Re: flat reed motor mountsRe: mit mortso mit mortso 05/29/14 02:09AM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 05/29/14 07:32AM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 05/29/14 07:40AM
  Re: flat reed motor mountsRe: Chris Toth Chris Toth 05/29/14 10:26AM
  Re: flat reed motor mountsRe: Richard Schwartz Richard Schwartz 05/29/14 07:01PM
  Re: flat reed motor mountsRe: † CH∆D † † CH∆D † 05/29/14 11:38PM
  Re: flat reed motor mountsRe: Cole Doubt Cole Doubt 05/30/14 02:13AM
  Re: flat reed motor mountsRe: mit mortso mit mortso 05/31/14 04:04PM
