Re: the right compression tester for mopeds<<<<<<<<<<<<<
Graham Motzing /
my MAC brand one from about 150 years ago has the schrader valve in the base, it takes a few more revolutions to 'pump up' the hose, but eventually it levels off and that is dead on measurement.
i don't use it for performance stuff, though, because static compression is mostly useless in light of the pipe supercharge and other factors affecting dynamic compression... i just use it for checking rings and stuff.
  the right compression tester for mopeds<<<<<<<<<<<<<Topic by: Ryan Mayer Ryan Mayer 09/27/11 05:24AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Heath Daniel Heath Daniel 09/27/11 11:26AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Mars   Mars   09/27/11 11:28AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Totally normal JBOT Totally normal JBOT 09/27/11 12:13PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Flagrant - Flagrant - 09/27/11 01:13PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Gerry F Gerry F 09/28/11 12:38PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Rachid Z Rachid Z 09/27/11 02:40PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Tim Mohr Tim Mohr 09/27/11 02:53PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: john doe john doe 09/27/11 08:38PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: matt boda1nz matt boda1nz 09/28/11 02:16PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Ryan Mayer Ryan Mayer 10/17/11 07:32AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Heath Daniel Heath Daniel 10/17/11 11:18AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Maciek Dub Maciek Dub 05/20/14 02:44AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: matt boda1nz matt boda1nz 10/17/11 12:03PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: cheetahchrome . cheetahchrome . 10/17/11 12:15PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Ryan Mayer Ryan Mayer 10/17/11 01:05PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: matt boda1nz matt boda1nz 10/17/11 03:12PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Flagrant - Flagrant - 10/17/11 03:28PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: mit mortso mit mortso 10/17/11 06:12PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: K Olena K Olena 10/17/11 09:02PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: matt boda1nz matt boda1nz 10/17/11 09:48PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Ross Maser Ross Maser 10/17/11 10:15PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: derek from black pipes moped gang 🌧 derek from black pipes moped gang 🌧 10/18/11 09:33AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: mit mortso mit mortso 10/18/11 06:11PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: matt boda1nz matt boda1nz 10/20/11 01:48PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Ryan Mayer Ryan Mayer 10/20/11 04:28PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Road Rash Dave Road Rash Dave 03/06/13 07:57AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Born to be WillD Born to be WillD 03/06/13 01:17PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Graham Motzing Graham Motzing 05/20/14 10:15AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Maciek Dub Maciek Dub 05/20/14 01:34PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Ryan Mayer Ryan Mayer 05/21/14 09:36PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: mit mortso mit mortso 05/22/14 10:15AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: matt boda1nz matt boda1nz 05/22/14 10:26AM
