Re: the right compression tester for mopeds<<<<<<<<<<<<<
Ryan Mayer /
my two piece tester had one schrader at the couple for pressure in and another schrader at the gauge for pressure out(when depressed of coarse). The first tube that screws into the head didn't have a schrader valve in it nor did it have threads for one. Therefore that first tube's volume between the head and first schrader(in the coupler) has to be added to the volume of the combustion chamber. Therefore what the gauge shows is lower than actual pressure with the sparkplug in.
  the right compression tester for mopeds<<<<<<<<<<<<<Topic by: Ryan Mayer Ryan Mayer 09/27/11 05:24AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Heath Daniel Heath Daniel 09/27/11 11:26AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Mars   Mars   09/27/11 11:28AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: JBOT Admin JBOT Admin 09/27/11 12:13PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Flagrant - Flagrant - 09/27/11 01:13PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Gerry F Gerry F 09/28/11 12:38PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Rachid Z Rachid Z 09/27/11 02:40PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Tim Mohr Tim Mohr 09/27/11 02:53PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: john doe john doe 09/27/11 08:38PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: matt boda1nz matt boda1nz 09/28/11 02:16PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Ryan Mayer Ryan Mayer 10/17/11 07:32AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Heath Daniel Heath Daniel 10/17/11 11:18AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Maciek Dub Maciek Dub 05/20/14 02:44AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: matt boda1nz matt boda1nz 10/17/11 12:03PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: cheetahchrome . cheetahchrome . 10/17/11 12:15PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Ryan Mayer Ryan Mayer 10/17/11 01:05PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: matt boda1nz matt boda1nz 10/17/11 03:12PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Flagrant - Flagrant - 10/17/11 03:28PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: mit mortso mit mortso 10/17/11 06:12PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: K Olena K Olena 10/17/11 09:02PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: matt boda1nz matt boda1nz 10/17/11 09:48PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Ross Maser Ross Maser 10/17/11 10:15PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: derek from black pipes moped gang 🌧 derek from black pipes moped gang 🌧 10/18/11 09:33AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: mit mortso mit mortso 10/18/11 06:11PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: matt boda1nz matt boda1nz 10/20/11 01:48PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Ryan Mayer Ryan Mayer 10/20/11 04:28PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Road Rash Dave Road Rash Dave 03/06/13 07:57AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Born to be WillD Born to be WillD 03/06/13 01:17PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Graham Motzing Graham Motzing 05/20/14 10:15AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Maciek Dub Maciek Dub 05/20/14 01:34PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: Ryan Mayer Ryan Mayer 05/21/14 09:36PM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: mit mortso mit mortso 05/22/14 10:15AM
  Re: the right compression tester for mopeds<<<<<<<<<<<<<Re: matt boda1nz matt boda1nz 05/22/14 10:26AM
