what's the best setup for hobbit
hello,
new to hobbits, and was wondering that the best setup was to get the most out of it. thanks
Re: what's the best setup for hobbit
If you have a pa50i, "kit it" because you cannot bolt on exhausts to the cylinder without going crazy and auger bit-ing the exhaust port, and even then its small.
If you have a pa50ii a lot of people just like to bolt on a nice exhaust and maybe reeds and are content with the speed from that.
Peter’s Formula: The Buddy Hobbit
Maybe even notch the variator, throw on a new belt, tension it correctly, grease your rollers, etc?
Started with a pa50i and I took the kit route, with a nice exhaust, pa50i carb drilled out, pa50ii gofast goodies (intake + reeds + ramp plate)
Insanely fast, Ill have to gps it but right now I'm breaking in my kit slowly.
William Johnson /
Are you seeking a money is not an issue answer, or you would like performance on a budget? There are alot of different set ups with Hobbits that one can be happy with, but if you want the fastest ped....
†▲m †▲m /
dr kit. proma. carbon or boyseen reeds. pa50i/graham light weights in the pa50ii variator. could notched/window your variator too. bx40 belt from 1977 (not treats... they are different belts)
~$250
