Tomos won't max out
So here is my situation:
I have a very low top speed. Maybe 25 mph
I can't really feel if it's 4 stroking (atleast not how my maxi feels, which is very obvious)
I'm working on the jetting now.
When I look at the wiki, everyone has a way higher jet then what I have now.
My plug is dark, which is telling me to down jet.
I figured I'd post what I have and see what some people think.
alukit
malossi 4p
polini phbg
tecno circuit
no air leaks, timing set correctly
ngk b7hs plug
I have a 78 jet in now.
I started at 90 and worked down this far.
Everyone in the wiki is like 88 or sometimes higher for this setup.
What am I doing wrong, or what should I look at changing?
thanks
Re: Tomos won't max out
You left out the size of the carb duder..is this on a tomos? (edited)
Sneaky Pure /
A35
phbg 19mm
This was verrrry helpful when I finished kitting and upgrading the carb this past spring:
http://www.mopedarmy.com/wiki/PHBG_tuning_made_easy._%28a_step_by_step_guide%29
Steve Dethrow /
I'm having a similar issue, I'm gonna try puttin a better throttle assembly on there.
Zeke Rigg /
do you have a restrictive air filter on there?
Sneaky Pure /
malossi, the squareish one.
use the same one of my maxi/polini and was wonderous.
I have your same setup..exactly, but on a za50. I am doing 45'ish..gearing 18x40..don't know how it compares though..78 jet also..
Sneaky Pure /
problem solved.
The gun I was using to try and set the cdi had to be funky.
whether i put the cdi at full advance or retard, all my marks always showed in same spot.
Got timing right.
80 jet in.
oh my god fast (i have a polini geared tall and am not used to all the redic low end)
the circuit pipe is wicked for low end on a tomos... best cheap pipe for tomos ever! my next build is another polini on a a35 with a circuit and phva 17.5.... nice everyday rider
Sneaky Pure /
I've been riding my maxi for sooo long.
It's a slips up until like 20 mph
this tomos has some torque.
pullin wheelies style.
Y/N?
Does the engine have new crankshaft seals? both sides.
Are you using the stock voltage reg. ?
TOMOS IS JUNK UNLESS U REBUILD MOTOR BEFORE BUYIN PARTS
