Re: E50 clutch nut loosening
Chris Paz /
first thing, do not pull the starter lever when the motor is running. It will cause premature wear the the starter plate and the starter clutch lining.
If your taper looks like shit then that IS your issue. Your clutch will never mate correctly with the crank with a damaged taper.
Sounds like there is also an issue with clutch bell spacing. Make sure the clutch bell has some float in and out and the correct series of circlips and spacers are being used. The bell should spin independently from the crank unless the clutch is engaging it.
  E50 clutch nut looseningTopic by: Ricky Lacapria Ricky Lacapria 06/15/11 02:15PM
  Re: E50 clutch nut looseningRe: Ryan N. Ryan N. 06/15/11 02:17PM
  Re: E50 clutch nut looseningRe: Ricky Lacapria Ricky Lacapria 06/15/11 02:29PM
  Re: E50 clutch nut looseningRe: Sneaky Pure Sneaky Pure 06/15/11 02:44PM
  Re: E50 clutch nut looseningRe: Un Lethocerus Un Lethocerus 06/15/11 03:07PM
  Re: E50 clutch nut looseningRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/15/11 06:29PM
  Re: E50 clutch nut looseningRe: Ricky Lacapria Ricky Lacapria 06/15/11 06:54PM
  Re: E50 clutch nut looseningRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 06/15/11 09:56PM
  Re: E50 clutch nut looseningRe: Ryan Steel Ryan Steel 06/15/11 10:01PM
  Re: E50 clutch nut looseningRe: Chris Paz Chris Paz 06/16/11 01:34AM
  Re: E50 clutch nut looseningRe: Chris Paz Chris Paz 06/16/11 01:36AM
  Re: E50 clutch nut looseningRe: Rachid Z Rachid Z 06/16/11 01:51AM
  Re: E50 clutch nut looseningRe: Pablo Puchasso Pablo Puchasso 06/16/11 04:44AM
  Re: E50 clutch nut looseningRe: Ricky Lacapria Ricky Lacapria 06/16/11 11:49AM
  Re: E50 clutch nut looseningRe: Chris Paz Chris Paz 06/16/11 02:04PM
  Re: E50 clutch nut looseningRe: Rachid Z Rachid Z 06/16/11 02:25PM
  Re: E50 clutch nut looseningRe: Ricky Lacapria Ricky Lacapria 06/16/11 03:11PM
  Re: E50 clutch nut looseningRe: JOEL K JOEL K 06/16/11 06:10PM
  Re: E50 clutch nut looseningRe: Pat Kelleher Pat Kelleher 06/18/11 12:23AM
