Re: E50 clutch nut loosening
Ricky Lacapria /
Paz the taper looks like shit now that I looked at it better, so that could be an issue, and I'm still having this issue, but not the loosening. I don't have a torque wrench right now, but it seems like if I crank it on there fairly good, the clutch is always engaging and spinning with the bell. Don't I want the clutch to spin on it's own till I pull the clutch cable, or it engages? And if I don't tighten it down crazy, it spins on it's own, but then I put the cover on, and it won't engage with the clutch lever, or it will barely. The arm on the cover will bend out farther than I've ever seen it.
This is ridiculous cause I've built this engine like 4 times and never had a single issue with it. Now I'm going nuts.
  E50 clutch nut looseningTopic by: Ricky Lacapria Ricky Lacapria 06/15/11 02:15PM
  Re: E50 clutch nut looseningRe: Ryan N. Ryan N. 06/15/11 02:17PM
  Re: E50 clutch nut looseningRe: Ricky Lacapria Ricky Lacapria 06/15/11 02:29PM
  Re: E50 clutch nut looseningRe: Sneaky Pure Sneaky Pure 06/15/11 02:44PM
  Re: E50 clutch nut looseningRe: Un Lethocerus Un Lethocerus 06/15/11 03:07PM
  Re: E50 clutch nut looseningRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/15/11 06:29PM
  Re: E50 clutch nut looseningRe: Ricky Lacapria Ricky Lacapria 06/15/11 06:54PM
  Re: E50 clutch nut looseningRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 06/15/11 09:56PM
  Re: E50 clutch nut looseningRe: Ryan Steel Ryan Steel 06/15/11 10:01PM
  Re: E50 clutch nut looseningRe: Chris Paz Chris Paz 06/16/11 01:34AM
  Re: E50 clutch nut looseningRe: Chris Paz Chris Paz 06/16/11 01:36AM
  Re: E50 clutch nut looseningRe: Rachid Z Rachid Z 06/16/11 01:51AM
  Re: E50 clutch nut looseningRe: Pablo Puchasso Pablo Puchasso 06/16/11 04:44AM
  Re: E50 clutch nut looseningRe: Ricky Lacapria Ricky Lacapria 06/16/11 11:49AM
  Re: E50 clutch nut looseningRe: Chris Paz Chris Paz 06/16/11 02:04PM
  Re: E50 clutch nut looseningRe: Rachid Z Rachid Z 06/16/11 02:25PM
  Re: E50 clutch nut looseningRe: Ricky Lacapria Ricky Lacapria 06/16/11 03:11PM
  Re: E50 clutch nut looseningRe: JOEL K JOEL K 06/16/11 06:10PM
  Re: E50 clutch nut looseningRe: Pat Kelleher Pat Kelleher 06/18/11 12:23AM
