Re: E50 clutch nut loosening
Rachid Z /
seriously? the range of correct tightness is from hand tight- to use an IMPACT?????
crazy.
i have had to apply like 150 or more foot pounds to a lug-nut to get it off on my car from some jackamo who put it on with however many pounds the gun puts out. just blows the mind.
The tool you are looking for is a torque wrench, when people say Torque it down or "torque it to spec" they don't mean as tight as you can go until you dot your underpants with a spec of pee.
they mean clutch nut 21-28ft/lbs then the wrench clicks and you double check and you take out the piston stop. Same with the Flywheel, and the engine studs, and the exhaust nuts........
the repair manual for everything usually has the specifications for all fasteners tightness.
  E50 clutch nut looseningTopic by: Ricky Lacapria Ricky Lacapria 06/15/11 02:15PM
  Re: E50 clutch nut looseningRe: Ryan N. Ryan N. 06/15/11 02:17PM
  Re: E50 clutch nut looseningRe: Ricky Lacapria Ricky Lacapria 06/15/11 02:29PM
  Re: E50 clutch nut looseningRe: Sneaky Pure Sneaky Pure 06/15/11 02:44PM
  Re: E50 clutch nut looseningRe: Un Lethocerus Un Lethocerus 06/15/11 03:07PM
  Re: E50 clutch nut looseningRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 06/15/11 06:29PM
  Re: E50 clutch nut looseningRe: Ricky Lacapria Ricky Lacapria 06/15/11 06:54PM
  Re: E50 clutch nut looseningRe: Matt Mahloch -- MBM Customs Matt Mahloch -- MBM Customs 06/15/11 09:56PM
  Re: E50 clutch nut looseningRe: Ryan Steel Ryan Steel 06/15/11 10:01PM
  Re: E50 clutch nut looseningRe: Chris Paz Chris Paz 06/16/11 01:34AM
  Re: E50 clutch nut looseningRe: Chris Paz Chris Paz 06/16/11 01:36AM
  Re: E50 clutch nut looseningRe: Rachid Z Rachid Z 06/16/11 01:51AM
  Re: E50 clutch nut looseningRe: Pablo Puchasso Pablo Puchasso 06/16/11 04:44AM
  Re: E50 clutch nut looseningRe: Ricky Lacapria Ricky Lacapria 06/16/11 11:49AM
  Re: E50 clutch nut looseningRe: Chris Paz Chris Paz 06/16/11 02:04PM
  Re: E50 clutch nut looseningRe: Rachid Z Rachid Z 06/16/11 02:25PM
  Re: E50 clutch nut looseningRe: Ricky Lacapria Ricky Lacapria 06/16/11 03:11PM
  Re: E50 clutch nut looseningRe: JOEL K JOEL K 06/16/11 06:10PM
  Re: E50 clutch nut looseningRe: Pat Kelleher Pat Kelleher 06/18/11 12:23AM
