boggin from the start
apoca lypsis /
2006 streetmate
installed unipod filter and technigas next pipe,62 jet.
my bike runs great from stops just before engine get hot but after the engine get hot when I pull full throttle from stop the bike act sound bogging and iddle change low and seems like it's going to die.
is it because too lean? or too rich?
Re: boggin from the start
check your plug. try to run with the choke on and see if it helps
apoca lypsis /
what should look for when i check the plug? I have uni filter so i think I am getting enough air I think? with 64 main jet
- Summerai - Drew /
Lean. Put your stock air filter back on.
apoca lypsis /
lean? hm..I have 64 now but I have 66,68 main jet, should I put them on and try again? or just put stock filter back on....
how could it be lean? I have 64 jet and with unifilter and technigas pipe...air leak? hm...
sounds lean.
go to the wiki and look how to correctly jet.
you can cure the problem by possibly putting on stock air box.
or you could upjet and then tune your carb.
Steve Dethrow /
U might wanna down jet, seems to high for just a filter and a pipe. Imrunnin a 66 with a kit.
UPJET DUMMY
Ricky Lacapria /
check your plug when this happens and if it's super black or wet you're to rich. then change something accordingly.
