Chappy LB50 Question
Will the head, cylinder jug, and piston (47mm) from an 80cc Champ directly bolt onto an LB50 Chappy's case?
Re: Chappy LB50 Question
ブロック 666 /
No it will not bottom of cylinder jug is to big to fit into crank case.
Yeah, and I believe the larger Chappy motors (LB80) have the same problem. Only thing to do is either kit it or break out the welder and replace it with something else.
Ok, makes sense about the bottom / skirt end of the cylinder not fitting...will prob look into kitting. Would the head from an LB80 Chappy fit?
