19mm dellorto race carb help
Steve Dethrow /
Any tips on installing this carb, also it is set up for a cable choke, do I need to run a cable to it or is there any other options.
Re: 19mm dellorto race carb help
There are two articles in the wiki that go into great depth about the PHBG.
They are beastly, but please take your time.
Also, if you don't want to run the cable choke you have a few different options.
go to 1977 or treats (or anywhere else you prefer) and look up all the different flips and levers and awesomess you can use for choke
