A35 polini 4p jetting range?
Hey,
I looked through the tuner's spreedsheet and didn't see a lot of these on there.
I have alukit, 19mm phbg, and a tecno circuit (for starters) to start with.
do you imagine I'd be in high 80s low 90s?
Re: A35 polini 4p jetting range?
high 70's low 80's, thats if you can even get your engine to choke down that much air from a 19mm.
I had a 17.5mm phbg that ran like garbage, switched to a 16 SHA with a 73 jet and all was golden.
Sneaky Pure /
And upjetting didn't help you? Or did you just not high high enough of a range to use?
