Re: Hobbit no idle
Silverfox Sullivan /
Here is the proceedure from the manual
Get the bike started and warmed up
run the idle speed screw in until you get a fast steady idle
run the idle air mixture screw in and out until you get the highest idle speed
run the idle speed screw out until you get a nice steady putt-putt-putt
Repeat if necessary
What shaneb said is absolutely necessary if the above doesnt work
