Has anyone experienced these gauges mis-reading their temperature? I'm working on squaring away a new build, and I'm getting temps of up to 500 degrees with only minor around-the-block riding. It will get up to 400 at idle. The bike seems to run well and both idles well and seems void of air leaks. Also after spending some time at "500 degrees", a teardown of the cylinder shows no damage at all to the piston (as it should have probably seized by then) so I'm thinking it's the trailtech.
Any insight into this, y'all?
P.S. Here's some monkeys:
