WEIGHT IN: Best Tomos Clutch Pad Material
GET REALIZED! BE HERE NOW! /
So all y'all guru types out there who are cutting up old lady handbags for leather and using gorilla juice glue and all that craziness...
WHAT IS THE BEST MATERIAL? I'm talking kitted and all that jazz, not some wimpy Sunday slow rider.
Re: WEIGHT IN: Best Tomos Clutch Pad Material
learther ist gear. Cork second gear
evan, if you ever can the chance to remove the clutches from that tomos you have check out the leather.
personally i like asbestos, try 'em both and see what you like.
evan OP
Yeah Ed I'll do that if I ever break her open.
Anyone use any of mcmaster Carr like friction materials?
evan OP
To
Graham; what sort of asbestos you using? Find strips somewhere?
i wanne try that mccmastercarr material. Wonder if they deliver to nl?
evan OP
The McMC stuff definitely is intruiging;
For the sake of bench racing here, what you want in clutch material is a high coefficient of friction, high max operating temp and pressure correct? So the Hugh friction molded sheets seem best...
scott, drop me a email, I will send you some if need be sir.
Dick Tortuga /
I'm currently using NAPA rubberized cork. Exact thickness and easy to work with and bond. What exactly do the various materials do, ie: last longer, grip harder, slip then grip, lower RPM engage, higher RPM engage...? Just curious before I start experimenting further. With the NAPA rubberized cork, first and second clutches, one diagonal groove on second, first engages with a slight slip and holds hard to 7K+ and I blip for shift. I realize a lot is the springs (stock), but just curious what other material does...
ok thanks Ed
put an a3 first gear clutch on the a35 clutch hub:
<iframe title="YouTube video player" width="480" height="390" src="http://www.youtube.com/embed/4d6tQWsbE70"; frameborder="0" allowfullscreen></iframe>
and i suck at the internet...
one more time...
Dude when I reline them I don't even have to take the clutch apart.
"relined":http://www.mopedarmy.com/forums/discuss/6/205491/205491/
I have found some thicker .090 rubber material that is made for clutches. Lets hope I get some and reline a set. It may not slip enough insteaad inst-grap.
yeah the 'friction material' sold by mcmaster-carr, which i have linked to a gagillion times, is what i'm calling 'asbestos'... its actually a composite ceramic sorta thing because they dont let you use asbestos for stuff anymore, but its basically 'asbestos-free asbestos'
thats what i use and it works great. truth be told i haven't put many miles on that engine because it needs a crazy custom CDI because of the pipe thats on it, but it does shift at about 12-13k rpm from 1-2 and it just about throws you off when it grabs second clutch at about 35-40 mph.
so yeah, i'd say its pretty durable.
evan OP
My fuck Graham that sounds tasty, which variety or the friction material are you using? Care to share what you are personally bonding it with?
uh just the strip shit on mcmaster. i use this epoxy stuff called PC7 for almost everything in my shop... from building up cases/transfers to gluing shit together... it saved an SHA by gluing the mounting clamp back on after it broke off, ran for a good 7000 more miles on my daily driver.
grind off everything with a wire wheel, get it surgical clean, rough it up a bit with emory cloth, glue the strip around the clutch and secure it with a hose clamp. when it dries grind off the excess and slice between the shoes with a dremel cutter disc.
i'm sure the leather is better for daily driver setups or something where you want a softer launch. i'm sure thats why tomos uses cork stock, because a3's shift hard as fuck and so does my hot rod clutches. it sounds like lots of people have used leather with great success, but if you want to really slip out your gears, asbestos is great.
mine are also lightened a bit but the spring is untouched... i think, actually i might have shortened the spring a little too.
▣ß@ηℊℙℐṔ∃▣ ™ /
Meh, roll O cork always worked for me
I plan to do a set with this magical stuff.
I will cut 2 or 3 diangle cuts into them before installing them.
They just came out off the 100watt light bulb.
evan OP
Dee heck is it? Imported from mars by the looks if it.
evan this is the best stuff I found so far for the wetclutch/dry clutch/brake shoes .. Make sure you know what you getting into when doing this need the good glues and press them and let dry 2 days wow stuff old man from that worked at raylock in my area showed me this stuff and the glue they used.
kevlar?
Ed, is that the semi-metallic friction material from McMaster? See all this shit:
Friction materials from McMaster. That black strip is the stuff Graham is talking about I believe. The green stuff is chrome leather, the thin yellow is 1/2" wide kevlar, the big yellow is 1" wide kevlar, I have vermiculite coated fiberglass, fiberglass, carbon fiber, and I've already tried the semi-metallic friction material, which is waaaaay too harsh, can't get it to slip enough for a smooth shift.
Oh yeah, I've used the rubberized cork gasket material, which I actually really like in terms of performance, but it doesn't last very long.
Awesome man, for sure let us know what you find. How do you find this stuff? The brake and clutch lining section of mcmaster only has a couple of those.
ha, neat! pic.
I think I am having ss 17-7 spring made for the clutches.
What pipe you running. The one leather clutches that I did slip nice tho you can't tell cause of the bighitter pipe.
On the minarelli v1's the springs I have hold them shoes it well using the stock parts. I hope it rips the bell in half.
I did a set of tomos 2nd gear clutch today I just to have wait until it cures. I read some of the glues take 7 days .. and is in the price range 80$ for 7oz's of it.
This was the last thing I tried, carbon fiber:
This is the semi-metallic brake and clutch lining:
This stuff works pretty well on first gear, doesn't work at all on second gear. The second gear clutch needs to be able to slip quite a bit, you don't want it to just grab, and that's what this stuff does. It doesn't slip at all, so you get a ton of shudder in the engine. Also, it comes in 3/16" (~5mm) thickness, which is about 2x what you need, and there's no easy way of cutting it. I bonded the material to the clutches and then turned it down on a lathe. Also, I think it's a fiber glass base material because the fibers it created when cutting it itched like fuck.
The carbon fiber didn't work so well only because it's woven more like wool than like the nice silky material you see in carbon fiber body panels and stuff. The nap of the material creates too much friction and you end up shifting into second at 10mph. The same thing happened with that big role of kevlar. Both of those materials are just too thick and nappy, and since they're fabrics there's no (easy) way to thin them. The little role of kevlar is not only thinner in width it's also much thinner in thickness, so I think it has a better chance of working.
If you search for "friction material" on McMaster you'll find all these things. The "brake and clutch lining molded sheets" stuff would probably be ideal, and come's in 1/8" thickness which would work well, but since it comes in huge 15" x 15" sheets it's really expensive. The stuff that comes in strips is way cheaper, but it's 3/16" thick and 1" inch wide. That's the "asbestos" nonmetallic molded strip that Graham is referring to, and the semi-metallic woven strip that is in my second photo.
Another problem with super high friction materials is that in order for them to work the way you want you need to clutch to engage much later than stock clutches do, which means cutting your springs. Also, since the Tomos clutch hubs and pins are steel and the shoes are aluminum cutting your springs and putting on high friction material that grabs really hard is going to lead to bad things (granted, this happens to Tomos clutches in kitted engines regardless of messing around with clutch linings):
