Re: Crazy wayne ported my kit and check it out "V
Tweaker trash /
> Taylor King wrote:
> > Tweaker trash wrote:
> > Ported by Wayne & installed by me
> Soooo are you saying you know Wayne?
It’s was a joke! Pro ported, amateur install
Looks like alotta blow down
> EH FCC of the QCB wrote:
> Forgot that thread was locked…..damn was going to bump it……just search
> it and enjoy…..Seriously I want to make the 13 port and maybe do some
> kind off internet’s give away. Idk 🤷🏼‍♂️. Winter is coming and that is
> cylinder cutting season
Do it. I'll buy one.
I would help you test it over the winter out here in sunny california. I dont have to worry about much poor riding weather. I'm not afraid of riding in the chilly weather.
It doesn’t seem that bad to do. I may do it to the 50cc kstar I have and toss it
Out for someone to try……before I destroy a new 70 kit. Probably leave a little more meat between the transfers and finger ports. Ill pull the kit out tonight and see if it is even possible on the 50cc one. 50cc cylinders are harder to cut sometimes because they are smaller and harder to move around inside.
I've got a lightly used 70cc kit not being used at the moment... I can send it your way! 👀
🤔. I mean it’s for science hahaha 🤘🏻. I would be down to try. Let me see how this 50cc one goes and I would give it a wack. I have some ideas how to make this happen close to the porting. He has done. I just want to know if it works or it is a complete turd.
Now how to get out of work and go home and mess with cylinders? (edited)
Jurrian Mulder /
I was reading this all above, has any of you ever hit the dyno with these '13 port' cylinders? Cause I think it's not going to be that spectacular... Here's some pics of my k star:
last week it ran 13.7hp on the dyno at 11500rpm. stops at 14500rpm.
Now that's a ported cylinder
Wow that's rad, I'm working on a cylinder reed adapted tccd50 right now, definitely going to look at this for inspiration!
Jurrian Mulder /
I have some better examples for that I think. just sent me a pb for that, I'm not gonna share that cylinder online
How’s that case induction look? What reeds and carb are you running? That looks awesome!
Also would the same concept work with cylinder induction still and still keep the third transfer like the “gilarini” or do you think it would make less power that way?
Jurrian Mulder /
> That looks awesome!
Case induction is welded om at the moment, but I'm not completely happy with that. Next crankcase is going to be a bolt om version. I'm tunning a vforce3 reed, and a mikuni tm24 carburator. The cylinder induction could work, but you will need a reedvalve.
Come on Tommy… Quit fucking around and get the torches out….
