what porting tools to use,port advice honda pa50
Tim /
Hi I have done some porting before but am looking for advice on tools and actual porting of my honda pa50 cylinder. When it comes to porting these it looks like you need a very small 90 degree or 45 degree dental type high speed port tool. I have a big straight air die grinder[1/8" collet] and a much smaller straight high speed air dental die grinder[1/16" type collet] but both of these don't look to do much good anywhere but in the exhaust port and maybe some of the sides of the transfers. Could anyone give me a tool that will work better to increase the port window size in these very small cylinders? I should say I also have all the measuring tools and even some of the special small bent files and carbides and die grinder rolls and other stuff needed. Next I was hoping for some opions on my porting idea. I was going to buy a replacement 70cc pistion and pin from one of the 70cc kits and bore and hone my stock cylinder out to fit that piston and basicly port the port sizes to what's listed in the wiki for the high performance p4 honda port size. I'd probley also have to do some head work. Thanks Tim
