Re: Make your headlight bright at any RPM
♣Slew Foot♣ /
This is worth of bump even though it's 10 years old because here's an update Schumacher 1315 is a USB compatible car jumper battery and has 800 Peak amped and 400 cranking so you wire this baby in and it is a lithium rechargeable that has everything you need to run an electrical system for a bike but I would just rig it so it ran an alternate system you could use 6 volt everything hell on this thing you could use 9 volt everything or 12 volt everything it even has a built-in flashlight it's really cool it was a find and they list for like 79 bucks but the wiring and everything it's just so simple
It has a Sony like AC plug well not really a c but it's for the jumpers for your car battery and you could just rig those the system Mars is talking about with the capacitors to absorb any extra overflow but you could just isolate the system and charge it with a regular USB thing it takes about 4 hours but it's worth it it lasts forever once it's charged and it does have an outer rubber cover but I don't trust the electronics to be out overnight so it's best that it's removable from your wiring harness
  Make your headlight bright at any RPMTopic by: Maddie Maddie 10/11/10 03:31AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/11/10 03:48AM
  Re: Make your headlight bright at any RPMRe: Maddie Maddie 10/11/10 03:57AM
  Re: Make your headlight bright at any RPMRe: Bobby Bou Bobby Bou 10/22/10 12:52AM
  Re: Make your headlight bright at any RPMRe: Graham Motzing Graham Motzing 10/11/10 10:49AM
  Re: Make your headlight bright at any RPMRe: murdoch murdoch 10/11/10 02:34PM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/11/10 02:45PM
  Re: Make your headlight bright at any RPMRe: Pavel Pavel 10/11/10 02:56PM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/11/10 03:02PM
  Re: Make your headlight bright at any RPMRe: * * * * 11/19/19 11:06PM
  Re: Make your headlight bright at any RPMRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/21/19 10:46AM
  Re: Make your headlight bright at any RPMRe: ken gilbert ken gilbert 11/21/19 02:15PM
  Re: Make your headlight bright at any RPMRe: Pavel Pavel 10/11/10 03:03PM
  Re: Make your headlight bright at any RPMRe: Pavel Pavel 10/11/10 04:04PM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/11/10 09:11PM
  Re: Make your headlight bright at any RPMRe: tim tim 10/11/10 09:47PM
  Re: Make your headlight bright at any RPMRe: Pavel Pavel 10/11/10 10:04PM
  Re: Make your headlight bright at any RPMRe: mark mark 10/12/10 09:14AM
  Re: Make your headlight bright at any RPMRe: Graham Motzing Graham Motzing 10/12/10 10:44AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/12/10 10:55AM
  Re: Make your headlight bright at any RPMRe: M Z M Z 10/12/10 11:04AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/12/10 11:15AM
  Re: Make your headlight bright at any RPMRe: Graham Motzing Graham Motzing 10/12/10 11:26AM
  Re: Make your headlight bright at any RPMRe: M Z M Z 10/12/10 12:51PM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/12/10 12:57PM
  Re: Make your headlight bright at any RPMRe: Maddie Maddie 10/12/10 04:35PM
  Re: Make your headlight bright at any RPMRe: P P 10/13/10 02:30PM
  Re: Make your headlight bright at any RPMRe: Maddie Maddie 10/21/10 01:27AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/21/10 01:36AM
  Re: Make your headlight bright at any RPMRe: Maddie Maddie 10/21/10 02:13AM
  Re: Make your headlight bright at any RPMRe: kenfong kenfong 10/23/10 11:56AM
  Re: Make your headlight bright at any RPMRe: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 10/23/10 12:11PM
  Re: Make your headlight bright at any RPMRe: P P 10/23/10 11:11PM
  Re: Make your headlight bright at any RPMRe: CtpEDsHED . CtpEDsHED . 10/24/10 12:58AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   11/30/10 03:07PM
  Re: Make your headlight bright at any RPMRe: big block fiero big block fiero 11/30/10 08:47PM
  Re: Make your headlight bright at any RPMRe: samsporter samsporter 12/01/10 02:56PM
  Re: Make your headlight bright at any RPMRe: Robbie Robbie 12/02/10 12:58AM
  Re: Make your headlight bright at any RPMRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/15/19 01:16AM
  Re: Make your headlight bright at any RPMRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/19/19 03:31PM
  Re: Make your headlight bright at any RPMRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/19/19 11:22PM
  Re: Make your headlight bright at any RPMRe: Probably Fred Probably Fred 11/21/19 05:02PM
  Re: Make your headlight bright at any RPMRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/23/19 06:51PM
  Re: Make your headlight bright at any RPMRe: Michael Jones Michael Jones 10/19/21 03:35AM
  Re: Make your headlight bright at any RPMRe: Dirty30 Dillon Dirty30 Dillon 10/19/21 09:51AM
  Re: Make your headlight bright at any RPMRe: b to the eff b to the eff 10/22/21 12:00PM
  Re: Make your headlight bright at any RPMRe: Totally normal JBOT Totally normal JBOT 10/22/21 12:52AM
  Re: Make your headlight bright at any RPMRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 10/19/21 09:28AM
  Re: Make your headlight bright at any RPMRe: Michael Jones Michael Jones 10/21/21 09:57PM
  Re: Make your headlight bright at any RPMRe: b to the eff b to the eff 10/22/21 12:15PM
