Re: Make your headlight bright at any RPM
Maddie /
The battery I got, a sealed - lead -acid (SLA) from Battery Mart (#SLA-12V1-3) has a cap in it that prevents it from exploding. So far the battery seems to be holding charge, I am running a 27 Watt xenon bulb, so I am assuming that I am putting out enough juice enough of the time to keep it charged.
The a55 (unless it's a sprint, which I think has a weaker light coil) should be able to maintain 25-30 Watts for a headlight. If you pull the 10W brake and 5W tail lights and replace them with LED's, you'd have even more juice. I just might do that. Prob only for brake, since you get no scatter with LED, and I'd like to still have my tail light seen from all angles.
Yeah, I like the cap and resistor idea. What size cap and resistor would I use?
Author: Mars (---.hsd1.ma.comcast.net)
Verified User: martian
* Date Posted: 10-11-10 13:45
Hey, how about putting a small cap (and resistor to drain the cap) between the bridge and the relay to give a constant level
  Make your headlight bright at any RPMTopic by: Maddie Maddie 10/11/10 03:31AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/11/10 03:48AM
  Re: Make your headlight bright at any RPMRe: Maddie Maddie 10/11/10 03:57AM
  Re: Make your headlight bright at any RPMRe: Bobby Bou Bobby Bou 10/22/10 12:52AM
  Re: Make your headlight bright at any RPMRe: Graham Motzing Graham Motzing 10/11/10 10:49AM
  Re: Make your headlight bright at any RPMRe: murdoch murdoch 10/11/10 02:34PM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/11/10 02:45PM
  Re: Make your headlight bright at any RPMRe: Pavel Pavel 10/11/10 02:56PM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/11/10 03:02PM
  Re: Make your headlight bright at any RPMRe: * * * * 11/19/19 11:06PM
  Re: Make your headlight bright at any RPMRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/21/19 10:46AM
  Re: Make your headlight bright at any RPMRe: ken gilbert ken gilbert 11/21/19 02:15PM
  Re: Make your headlight bright at any RPMRe: Pavel Pavel 10/11/10 03:03PM
  Re: Make your headlight bright at any RPMRe: Pavel Pavel 10/11/10 04:04PM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/11/10 09:11PM
  Re: Make your headlight bright at any RPMRe: tim tim 10/11/10 09:47PM
  Re: Make your headlight bright at any RPMRe: Pavel Pavel 10/11/10 10:04PM
  Re: Make your headlight bright at any RPMRe: mark mark 10/12/10 09:14AM
  Re: Make your headlight bright at any RPMRe: Graham Motzing Graham Motzing 10/12/10 10:44AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/12/10 10:55AM
  Re: Make your headlight bright at any RPMRe: M Z M Z 10/12/10 11:04AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/12/10 11:15AM
  Re: Make your headlight bright at any RPMRe: Graham Motzing Graham Motzing 10/12/10 11:26AM
  Re: Make your headlight bright at any RPMRe: M Z M Z 10/12/10 12:51PM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/12/10 12:57PM
  Re: Make your headlight bright at any RPMRe: Maddie Maddie 10/12/10 04:35PM
  Re: Make your headlight bright at any RPMRe: P P 10/13/10 02:30PM
  Re: Make your headlight bright at any RPMRe: Maddie Maddie 10/21/10 01:27AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/21/10 01:36AM
  Re: Make your headlight bright at any RPMRe: Maddie Maddie 10/21/10 02:13AM
  Re: Make your headlight bright at any RPMRe: kenfong kenfong 10/23/10 11:56AM
  Re: Make your headlight bright at any RPMRe: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 10/23/10 12:11PM
  Re: Make your headlight bright at any RPMRe: P P 10/23/10 11:11PM
  Re: Make your headlight bright at any RPMRe: CtpEDsHED . CtpEDsHED . 10/24/10 12:58AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   11/30/10 03:07PM
  Re: Make your headlight bright at any RPMRe: big block fiero big block fiero 11/30/10 08:47PM
  Re: Make your headlight bright at any RPMRe: samsporter samsporter 12/01/10 02:56PM
  Re: Make your headlight bright at any RPMRe: Robbie Robbie 12/02/10 12:58AM
  Re: Make your headlight bright at any RPMRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/15/19 01:16AM
  Re: Make your headlight bright at any RPMRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/19/19 03:31PM
  Re: Make your headlight bright at any RPMRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/19/19 11:22PM
  Re: Make your headlight bright at any RPMRe: Probably Fred Probably Fred 11/21/19 05:02PM
  Re: Make your headlight bright at any RPMRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/23/19 06:51PM
  Re: Make your headlight bright at any RPMRe: Michael Jones Michael Jones 10/19/21 03:35AM
  Re: Make your headlight bright at any RPMRe: Dirty30 Dillon Dirty30 Dillon 10/19/21 09:51AM
  Re: Make your headlight bright at any RPMRe: b to the eff b to the eff 10/22/21 12:00PM
  Re: Make your headlight bright at any RPMRe: Totally normal JBOT Totally normal JBOT 10/22/21 12:52AM
  Re: Make your headlight bright at any RPMRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 10/19/21 09:28AM
  Re: Make your headlight bright at any RPMRe: Michael Jones Michael Jones 10/21/21 09:57PM
  Re: Make your headlight bright at any RPMRe: b to the eff b to the eff 10/22/21 12:15PM
