Make your headlight bright at any RPM
Maddie /
I ride alot at night in the city and got tired of not being able to use my blinker, hold the brake with the brake light on, have a headlight on and honk all at the same time, while idling at some hilly SF intersection with insane SUV drivers on cellphones trying to kill me.
This circuit allows you to use a small battery as a buffer for times when you drop below minmum voltage needed to light your 'ped. Works just like a car circuit. When the 'ped is revving, it powers the light and charges the battery. When the 'ped is under-revving, it runs in reverse and the battery powers the light. No more flicker-flicker and no more dim-dim. The battery I used (1.3amp-hour) should give you about 20+ minutes of lighting backup at slow idle, which is far more than you need for a 2-3 minute long traffic light.
The rectifiers isolate each circuit and allow you to use a relay to automatically turn the light on and off when the 'ped is running or off. Otherwise, you'd have to use a switch to turn the light on and off. This might result in forgetting to turn on the light during the day, or forgetting to turn OFF the light during the day, which would drain your battery down to zero, and ultimately kill the cells.
The second rectifier circuit powers a SPST switch which basically closes the circuit between the battery and the light when voltage is sensed (i.e. the 'ped is running). When the 'ped is off, the switch opens, the light turns off and the battery stays charged. If you did this whole project with just one rectifier circuit, it would work, but the battery would remain connected to the coil of the switch when the 'ped is off, and might ultimately drain down if it's parked for a while. It's just a few extra wires and connectors and maybe $3 more, and I always like to avoid deep cycling of lead-acid batterys as much as possible.
I attached the circuit diagram for a super cheap and super quick fix. It works for my 2009 Tomos ST, which is 12V AC with chassis ground and is already regulated coming off the coil. Of course it might work for tons of other 'peds too. I am also sure there are 20 ways to do this mod and not everyone will think it's cool to want to use your horn/signals etc... Whatevs, for those who do, here it is.
Basically the idea is to avoid murking with the existing headlight/headlight switch circuit which could be frought with calamity if you clip the wrong wire or even look at one of the harnesses funny. Just ignore that circuit and go with a single beam (i.e. no high/low) lamp circuit.
You need:
2 Radio Shack 50v 25amp full wave bridge rectifiers (like $3 each)
Some 12/14 ga primary wire
Bunch of 1/4" male and female fasteners, and twist-top wire connectors
1.3 amp-hour lead-acid rechargable battery (weighs 1.5lbs, cost about $15 from BatteryMart.com)
SPST switch from any auto place (maybe $5)
1) Tap into one of the leads coming out of the 12V AC regulator, which comes off the lighting coil. Run this to wherever you are going to store the guts of your assembly. I put mine under the seat, since I long ago chucked the oil injector.
2) Split this 12 V AC tap into each of your two rectifiers. Connect the other AC terminal on the rectifier to the chassis.
3) One rectifier will be the switch circuit. Wire the +/- out of the rectifier to the coil terminals on the SPST switch.
4) The other rectifier will be the light/battery circuit. Run the + from the rectifier to the battery and to the light (parallel), and run the - to the battery and to one of the two switched terminals on the SPST switch (parallel).
5) Connect the other light terminal to the other switched terminal on the SPST.
6) I ran the wire from the regulator and the two wires to the headlight through the oil level checker hole in the seat pan, then under the left side cover and up the conduit under the gas tank to the triple tree, and then into the headlight pod. Wire ties/tape etc... yadda yadda yadda.
7) Get a blindingly bright xenon light / halogen / tractor bulb and blind everyone while you finally can see the road in front of you.
  Make your headlight bright at any RPMTopic by: Maddie Maddie 10/11/10 03:31AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/11/10 03:48AM
  Re: Make your headlight bright at any RPMRe: Maddie Maddie 10/11/10 03:57AM
  Re: Make your headlight bright at any RPMRe: Bobby Bou Bobby Bou 10/22/10 12:52AM
  Re: Make your headlight bright at any RPMRe: Graham Motzing Graham Motzing 10/11/10 10:49AM
  Re: Make your headlight bright at any RPMRe: murdoch murdoch 10/11/10 02:34PM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/11/10 02:45PM
  Re: Make your headlight bright at any RPMRe: Pavel Pavel 10/11/10 02:56PM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/11/10 03:02PM
  Re: Make your headlight bright at any RPMRe: * * * * 11/19/19 11:06PM
  Re: Make your headlight bright at any RPMRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/21/19 10:46AM
  Re: Make your headlight bright at any RPMRe: ken gilbert ken gilbert 11/21/19 02:15PM
  Re: Make your headlight bright at any RPMRe: Pavel Pavel 10/11/10 03:03PM
  Re: Make your headlight bright at any RPMRe: Pavel Pavel 10/11/10 04:04PM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/11/10 09:11PM
  Re: Make your headlight bright at any RPMRe: tim tim 10/11/10 09:47PM
  Re: Make your headlight bright at any RPMRe: Pavel Pavel 10/11/10 10:04PM
  Re: Make your headlight bright at any RPMRe: mark mark 10/12/10 09:14AM
  Re: Make your headlight bright at any RPMRe: Graham Motzing Graham Motzing 10/12/10 10:44AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/12/10 10:55AM
  Re: Make your headlight bright at any RPMRe: M Z M Z 10/12/10 11:04AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/12/10 11:15AM
  Re: Make your headlight bright at any RPMRe: Graham Motzing Graham Motzing 10/12/10 11:26AM
  Re: Make your headlight bright at any RPMRe: M Z M Z 10/12/10 12:51PM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/12/10 12:57PM
  Re: Make your headlight bright at any RPMRe: Maddie Maddie 10/12/10 04:35PM
  Re: Make your headlight bright at any RPMRe: P P 10/13/10 02:30PM
  Re: Make your headlight bright at any RPMRe: Maddie Maddie 10/21/10 01:27AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   10/21/10 01:36AM
  Re: Make your headlight bright at any RPMRe: Maddie Maddie 10/21/10 02:13AM
  Re: Make your headlight bright at any RPMRe: kenfong kenfong 10/23/10 11:56AM
  Re: Make your headlight bright at any RPMRe: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 10/23/10 12:11PM
  Re: Make your headlight bright at any RPMRe: P P 10/23/10 11:11PM
  Re: Make your headlight bright at any RPMRe: CtpEDsHED . CtpEDsHED . 10/24/10 12:58AM
  Re: Make your headlight bright at any RPMRe: Mars   Mars   11/30/10 03:07PM
  Re: Make your headlight bright at any RPMRe: big block fiero big block fiero 11/30/10 08:47PM
  Re: Make your headlight bright at any RPMRe: samsporter samsporter 12/01/10 02:56PM
  Re: Make your headlight bright at any RPMRe: Robbie Robbie 12/02/10 12:58AM
  Re: Make your headlight bright at any RPMRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/15/19 01:16AM
  Re: Make your headlight bright at any RPMRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/19/19 03:31PM
  Re: Make your headlight bright at any RPMRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 11/19/19 11:22PM
  Re: Make your headlight bright at any RPMRe: Probably Fred Probably Fred 11/21/19 05:02PM
  Re: Make your headlight bright at any RPMRe: ♣Slew Foot♣ ♣Slew Foot♣ 11/23/19 06:51PM
  Re: Make your headlight bright at any RPMRe: Michael Jones Michael Jones 10/19/21 03:35AM
  Re: Make your headlight bright at any RPMRe: Dirty30 Dillon Dirty30 Dillon 10/19/21 09:51AM
  Re: Make your headlight bright at any RPMRe: b to the eff b to the eff 10/22/21 12:00PM
  Re: Make your headlight bright at any RPMRe: Totally normal JBOT Totally normal JBOT 10/22/21 12:52AM
  Re: Make your headlight bright at any RPMRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 10/19/21 09:28AM
  Re: Make your headlight bright at any RPMRe: Michael Jones Michael Jones 10/21/21 09:57PM
  Re: Make your headlight bright at any RPMRe: b to the eff b to the eff 10/22/21 12:15PM
