Re: SSXL + EBR = Sweet Ride
Road Rash Dave /
Did you square up the lower end of the head tube to the top?
Because that cut is crooked and the bearing will be loose one way and bind the other....that is a good way to go if you have no welder as long as both ends of the head tube are square to one another...If you have access to a welder use the factory bearings and tread set welded to the EBR's..
Looks good
