peugeot variator mod how to
johno roberts /
i recently was asked about vario tuning for peugeots. it is a pain in the ass but can be done. and can be done well with a little effort so here ya go
you will need
bench vice
phillips screw driver
cressent wrench
drill
dremel
and a marker
1. remove your variator from the bike. if you dont know how this is done stop now and learn how your bike comes apart
2. disasemble the clutch put vario in the vice, remove nut which hold the vario togather disasemble the vario
3. now using the phillips driver remove the weights
4.mark out how much meterial you want to remove start with small amounts then get crazy
5. i also drill holes in the lead weights
6. use a scale and make sure the 2 weights weigh the same
7.you can see them side by side to see how much i remove
just so you know this vario will NOT start to shift till about 25-35mph so make sure you can spin the rpm to shift it
also my spelling is horrible sorry for all of the typos
hope this is helpfull to the poor people of the world
  peugeot variator mod how toTopic by: johno roberts johno roberts 03/28/10 03:08AM
  Re: peugeot variator mod how toRe: justin turner justin turner 03/28/10 03:16AM
  Re: peugeot variator mod how toRe: Emperor Swagustus Emperor Swagustus 03/28/10 03:22AM
  Re: peugeot variator mod how toRe: johno roberts johno roberts 03/28/10 03:41AM
  Re: peugeot variator mod how toRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 03/28/10 03:49AM
  Re: peugeot variator mod how toRe: johno roberts johno roberts 03/28/10 04:09AM
  Re: peugeot variator mod how toRe: mit mortso mit mortso 03/28/10 04:42AM
  Re: peugeot variator mod how toRe: naz naz 03/28/10 04:53AM
  Re: peugeot variator mod how toRe: Dan Dan 03/28/10 04:53AM
  Re: peugeot variator mod how toRe: Tom STL Tom STL 03/28/10 12:00PM
  Re: peugeot variator mod how toRe: johno roberts johno roberts 03/28/10 02:53PM
  Re: peugeot variator mod how toRe: Grant Grant 03/28/10 04:01PM
  Re: peugeot variator mod how toRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 03/28/10 10:00PM
  Re: peugeot variator mod how toRe: naz naz 03/28/10 04:48PM
  Re: peugeot variator mod how toRe: CtpEDsHED . CtpEDsHED . 03/28/10 09:34PM
  Re: peugeot variator mod how toRe: johno roberts johno roberts 03/28/10 09:41PM
  Re: peugeot variator mod how toRe: Grant Grant 03/29/10 01:44AM
  Re: peugeot variator mod how toRe: Eric Sabatino Eric Sabatino 03/29/10 02:32AM
  Re: peugeot variator mod how toRe: bolig bolig 03/30/10 10:36PM
  Re: peugeot variator mod how toRe: CtpEDsHED . CtpEDsHED . 03/31/10 08:42AM
  Re: peugeot variator mod how toRe: Tom STL Tom STL 03/31/10 12:52PM
  Re: peugeot variator mod how toRe: Mo Peds Mo Peds 10/15/10 04:04PM
  Re: peugeot variator mod how toRe: Mo Peds Mo Peds 10/23/10 05:07AM
  Re: peugeot variator mod how toRe: M-Tenn Aaron M-Tenn Aaron 10/16/10 10:01AM
  Re: peugeot variator mod how toRe: old DREW old DREW 10/16/10 10:07AM
  Re: peugeot variator mod how toRe: johno roberts johno roberts 10/16/10 07:15PM
  Re: peugeot variator mod how toRe: Steve Steve 10/16/10 09:14PM
  Re: peugeot variator mod how toRe: CtpEDsHED . CtpEDsHED . 10/23/10 11:32AM
  Re: peugeot variator mod how toRe: M-Tenn Aaron M-Tenn Aaron 10/24/10 11:03AM
  Re: peugeot variator mod how toRe: CtpEDsHED . CtpEDsHED . 10/24/10 11:27AM
  Re: peugeot variator mod how toRe: M-Tenn Aaron M-Tenn Aaron 10/24/10 04:13PM
  Re: peugeot variator mod how toRe: Jake P Jake P 02/04/12 03:16PM
  Re: peugeot variator mod how toRe: william hautenredi william hautenredi 02/06/12 12:29AM
  Re: peugeot variator mod how toRe: Aeron Jackson Aeron Jackson 04/30/12 04:08PM
  Re: peugeot variator mod how toRe: ♣ HOOLIGAN ♣ HOOLIGAN 04/30/12 05:07PM
  Re: peugeot variator mod how toRe: Aeron Jackson Aeron Jackson 04/30/12 05:29PM
  Re: peugeot variator mod how toRe: Chris Temple Chris Temple 09/22/21 07:03PM
  Re: peugeot variator mod how toRe: pat splat pat splat 09/23/21 12:06AM
  Re: peugeot variator mod how toRe: Toledo Riot Toledo Riot 09/24/21 06:45PM
