Honda Parma Kit Port Timing
I.R.E. Rick /
OK , so I am less then thrilled with this Parmakit . dont get me wrong , its not a hunk of junk . I just had lofty expectations . After case matching I assembled the bottom end , went to slide the kit only to see more disapointment . The exhaust ,at BDC opens almost 99% and the transfers about 75% . WTF I do understand that I can add base gaskets or make a spacer to correct this but then I'll need a custom milled head to extend into the cylinder . This is a honda kit , right ? What are other Parmakit owners doing to solve this ? I dont want to mill down the kit to get compression back , nor do I want to "just run it " . I'm searching for any other alternative options .
Want to reply to this thread?
