Re: idle switches rpms at consistent rate of 5 sec
Andy Haldeman /
well if you're checking the seals you wont be able to do it while it's running anyway. best way would be to use a pressure tester, plug up the exhaust port, take the carb off and hand pump air into the crankcase while piston is at tdc. take the magneto off, stator off, etc, and put some soapy water around the seal. you'll see if it bubbles. it's pretty involved i know...maybe there's an easier way somebody else can tell you
  idle switches rpms at consistent rate of 5 secondsTopic by: —— ¢hief —— —— ¢hief —— 03/04/10 10:35AM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 10:40AM
  Re: idle switches rpms at consistent rate of 5 secRe: tweeder tweeder 03/04/10 10:40AM
  Re: idle switches rpms at consistent rate of 5 secRe: young neezy young neezy 03/04/10 10:43AM
  Re: idle switches rpms at consistent rate of 5 secRe: Colin R. Colin R. 03/04/10 10:46AM
  Re: idle switches rpms at consistent rate of 5 secRe: Gabe Bandit Gabe Bandit 03/04/10 10:46AM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 10:52AM
  Re: idle switches rpms at consistent rate of 5 secRe: Jesse -B Jesse -B 03/04/10 11:55AM
  Re: idle switches rpms at consistent rate of 5 secRe: Colin R. Colin R. 03/04/10 12:00PM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 01:56PM
  Re: idle switches rpms at consistent rate of 5 secRe: mit mortso mit mortso 03/04/10 02:16PM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 02:32PM
  Re: idle switches rpms at consistent rate of 5 secRe: tweeder tweeder 03/04/10 02:37PM
  Re: idle switches rpms at consistent rate of 5 secRe: Andy Haldeman Andy Haldeman 03/04/10 03:24PM
  Re: idle switches rpms at consistent rate of 5 secRe: Jesse -B Jesse -B 03/04/10 04:42PM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 04:44PM
  Re: idle switches rpms at consistent rate of 5 secRe: tweeder tweeder 03/04/10 04:48PM
  Re: idle switches rpms at consistent rate of 5 secRe: Andy Haldeman Andy Haldeman 03/04/10 09:27PM
Want to reply to this thread?
