Re: idle switches rpms at consistent rate of 5 sec
Andy Haldeman /
according to the dellorto manual that is a textbook symptom of too-lean idle circuit. i had the same problem with my minarelli after stepping down an idle jet size. throttle response is better, but probably not worth it at the risk of seizing after running the engine hard and then slowing down to a lean idle..SCREEECH. check your mixture/idle screws. idle jet could be a possibility after that. airleaks of course too. did you check the stator side seal after installing the cdi? there's always a chance something could have happenned there
  idle switches rpms at consistent rate of 5 secondsTopic by: —— ¢hief —— —— ¢hief —— 03/04/10 10:35AM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 10:40AM
  Re: idle switches rpms at consistent rate of 5 secRe: tweeder tweeder 03/04/10 10:40AM
  Re: idle switches rpms at consistent rate of 5 secRe: young neezy young neezy 03/04/10 10:43AM
  Re: idle switches rpms at consistent rate of 5 secRe: Colin R. Colin R. 03/04/10 10:46AM
  Re: idle switches rpms at consistent rate of 5 secRe: Gabe Bandit Gabe Bandit 03/04/10 10:46AM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 10:52AM
  Re: idle switches rpms at consistent rate of 5 secRe: Jesse -B Jesse -B 03/04/10 11:55AM
  Re: idle switches rpms at consistent rate of 5 secRe: Colin R. Colin R. 03/04/10 12:00PM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 01:56PM
  Re: idle switches rpms at consistent rate of 5 secRe: mit mortso mit mortso 03/04/10 02:16PM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 02:32PM
  Re: idle switches rpms at consistent rate of 5 secRe: tweeder tweeder 03/04/10 02:37PM
  Re: idle switches rpms at consistent rate of 5 secRe: Andy Haldeman Andy Haldeman 03/04/10 03:24PM
  Re: idle switches rpms at consistent rate of 5 secRe: Jesse -B Jesse -B 03/04/10 04:42PM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 04:44PM
  Re: idle switches rpms at consistent rate of 5 secRe: tweeder tweeder 03/04/10 04:48PM
  Re: idle switches rpms at consistent rate of 5 secRe: Andy Haldeman Andy Haldeman 03/04/10 09:27PM
Click here to login.
