Re: idle switches rpms at consistent rate of 5 sec
—— ¢hief —— /
I've soaked the whole top end in carb cleaner trying to find airleaks..pretty grizzled when it starts smoking all over.. no sign of leaks though.
That phbg tuning process is in the wiki, which I read a ton of times before I got it, but admittingly didn't actually undergo because throttle response was so right on the first time without doing anything..I should probably do that. Just seems weird it could variate RPMs at such a constant rate like that. I've had air leaks before and always much more erratic/unpredictable
  idle switches rpms at consistent rate of 5 secondsTopic by: —— ¢hief —— —— ¢hief —— 03/04/10 10:35AM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 10:40AM
  Re: idle switches rpms at consistent rate of 5 secRe: tweeder tweeder 03/04/10 10:40AM
  Re: idle switches rpms at consistent rate of 5 secRe: young neezy young neezy 03/04/10 10:43AM
  Re: idle switches rpms at consistent rate of 5 secRe: Colin R. Colin R. 03/04/10 10:46AM
  Re: idle switches rpms at consistent rate of 5 secRe: Gabe Bandit Gabe Bandit 03/04/10 10:46AM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 10:52AM
  Re: idle switches rpms at consistent rate of 5 secRe: Jesse -B Jesse -B 03/04/10 11:55AM
  Re: idle switches rpms at consistent rate of 5 secRe: Colin R. Colin R. 03/04/10 12:00PM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 01:56PM
  Re: idle switches rpms at consistent rate of 5 secRe: mit mortso mit mortso 03/04/10 02:16PM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 02:32PM
  Re: idle switches rpms at consistent rate of 5 secRe: tweeder tweeder 03/04/10 02:37PM
  Re: idle switches rpms at consistent rate of 5 secRe: Andy Haldeman Andy Haldeman 03/04/10 03:24PM
  Re: idle switches rpms at consistent rate of 5 secRe: Jesse -B Jesse -B 03/04/10 04:42PM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 04:44PM
  Re: idle switches rpms at consistent rate of 5 secRe: tweeder tweeder 03/04/10 04:48PM
  Re: idle switches rpms at consistent rate of 5 secRe: Andy Haldeman Andy Haldeman 03/04/10 09:27PM
Want to reply to this thread?
