Re: idle switches rpms at consistent rate of 5 sec
tweeder /
sounds more like you need to adjust your idle mix screw. there is an old thread on this forum that details a process of how to do it. the short version is: warm engine to full operating temp. put bike up on stand. raise your idle rpms up a bit with slide adjusting screw. then find your mix by adjusting the mix screw until you get the most consistant idle speed. it takes a good 10 to 30 secs between each adjustment for the change to settle in. be patient. then lower your idle rpms back to normal and take it for a spin.
  idle switches rpms at consistent rate of 5 secondsTopic by: —— ¢hief —— —— ¢hief —— 03/04/10 10:35AM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 10:40AM
  Re: idle switches rpms at consistent rate of 5 secRe: tweeder tweeder 03/04/10 10:40AM
  Re: idle switches rpms at consistent rate of 5 secRe: young neezy young neezy 03/04/10 10:43AM
  Re: idle switches rpms at consistent rate of 5 secRe: Colin R. Colin R. 03/04/10 10:46AM
  Re: idle switches rpms at consistent rate of 5 secRe: Gabe Bandit Gabe Bandit 03/04/10 10:46AM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 10:52AM
  Re: idle switches rpms at consistent rate of 5 secRe: Jesse -B Jesse -B 03/04/10 11:55AM
  Re: idle switches rpms at consistent rate of 5 secRe: Colin R. Colin R. 03/04/10 12:00PM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 01:56PM
  Re: idle switches rpms at consistent rate of 5 secRe: mit mortso mit mortso 03/04/10 02:16PM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 02:32PM
  Re: idle switches rpms at consistent rate of 5 secRe: tweeder tweeder 03/04/10 02:37PM
  Re: idle switches rpms at consistent rate of 5 secRe: Andy Haldeman Andy Haldeman 03/04/10 03:24PM
  Re: idle switches rpms at consistent rate of 5 secRe: Jesse -B Jesse -B 03/04/10 04:42PM
  Re: idle switches rpms at consistent rate of 5 secRe: —— ¢hief —— —— ¢hief —— 03/04/10 04:44PM
  Re: idle switches rpms at consistent rate of 5 secRe: tweeder tweeder 03/04/10 04:48PM
  Re: idle switches rpms at consistent rate of 5 secRe: Andy Haldeman Andy Haldeman 03/04/10 09:27PM
Want to reply to this thread?
