Re: Crankshaft bearing play
xamboozi /
No the shim or washer is installed, but the bearing is just a little loose. Idk I pressed the clutch side bearing into the case and now it seems tighter than before...(is it my imagination?) I cant put the whole thing back together yet(still building it) but I'm hoping it will get better on the magneto side as well once its pressed in.
I'm worried that after I have it back together, the bearings will seize with the stress of the 80cc kit.
Want to reply to this thread?
