Re: spark plug cable came off while blasting
The kill switch makes a connection between ignition coil and ground that bypasses the plug wire. Then the bike stops firing.
Okay, so the _result_ is the same. Not going to argue with that.
It's just that you shouldn't think that you can just wire a household light switch inline with your plug wire to stop your engine.
Want to reply to this thread?
