Re: Puch setup with Dellorto?
Jaykayoh /
Did you port your cyclindar. Stock puch cylinders have about a 14.5mm intake port. Your 20mm carb is almost twice the size of the intake. It will never run right, unless you post your cyclindar to have that much volume. I think that 20mm is possible, but you are really pushing the limits of what is possible on a stock cylindar. Without porting it will never run right. I would stop worrying about jetting to you match your intake.
  Puch setup with Dellorto?Topic by: Wiggles Wiggles 03/03/10 02:49AM
  Re: Puch setup with Dellorto?Re: Wiggles Wiggles 03/03/10 02:57AM
  Re: Puch setup with Dellorto?Re: anthony anthony 03/03/10 03:29AM
  Re: Puch setup with Dellorto?Re: coco coco 03/03/10 03:30AM
  Re: Puch setup with Dellorto?Re: mit mortso mit mortso 03/03/10 11:20AM
  Re: Puch setup with Dellorto?Re: Wiggles Wiggles 03/03/10 12:17PM
  Re: Puch setup with Dellorto?Re: Jaykayoh Jaykayoh 03/03/10 01:04PM
  Re: Puch setup with Dellorto?Re: Wiggles Wiggles 03/03/10 03:05PM
  Re: Puch setup with Dellorto?Re: Tom STL Tom STL 03/03/10 01:24PM
  Re: Puch setup with Dellorto?Re: coco coco 03/03/10 03:31PM
  Re: Puch setup with Dellorto?Re: fishstics fishstics 03/03/10 07:35PM
  Re: Puch setup with Dellorto?Re: rofman rofman 03/03/10 07:42PM
  Re: Puch setup with Dellorto?Re: brad brad 03/04/10 11:05AM
  Re: Puch setup with Dellorto?Re: Wiggles Wiggles 03/04/10 12:18PM
  PhotosRe: Wiggles Wiggles 03/05/10 05:09PM
  Re: PhotosRe: coco coco 03/05/10 05:48PM
  Re: PhotosRe: coco coco 03/05/10 05:49PM
  Here are the correct specs...Re: Wiggles Wiggles 03/05/10 06:22PM
  Re: Here are the correct specs...Re: revdub . revdub . 03/05/10 08:34PM
  cylinder?Re: Wiggles Wiggles 03/05/10 09:30PM
  Re: Here are the correct specs...Re: Nash . Nash . 03/05/10 08:48PM
  Re: cylinder?Re: mit mortso mit mortso 03/06/10 05:13AM
  Re: cylinder?Re: mit mortso mit mortso 03/06/10 05:15AM
  Re: cylinder?Re: Wiggles Wiggles 03/07/10 05:21PM
Click here to login.
