Re: benelli g2 carb question
Jesse Stephenson /
Alright, to start with they make different shims for SHA carbs so they can mount onto many different intakes. Measure the intake diameter and get the right shim. You can put a 15mm SHA right on and the intake itself is about the right size on the inside. 1977 sells some kits for it so there is that. No native pipes but you can make something happen or order one from Motomatic. The clutch is the same an E50 so you can get some good clutch action on as well. It's a Dansi ignition but you may be able to find something that CDI like. There is a lot you can do if you are crafty.
Want to reply to this thread?
