Re: Shopping list for Tomos A3?
Colin R. /
I have a A3N and the intake on a Kit uses a 4 bolt set up. Our A3 uses a 2 bolt setup. The bushing is a necessary, but you will need to get a new intake manifold there about $30. a Side mount intake is most likely what will work because your carb might not fit under the frame where the stock one was. but that is basically all you you need to KIT.
Want to reply to this thread?
