Pipe for Solo Odyssey ???
M-Tenn Aaron /
Can anyone suggest a pipe that will work on a Solo Odyssey ? I know the only ones that are made for it are in Germany but I want to have a real expansion chamber that works.
The motor is at a 45 and the header bolts on like almost every other header. I plan to cut and weld another header to a decent pipe. There are no kits I know of for the motor so this is just a small mod.
The problems I have are that a pipe that goes under the motor will either hit the front wheel or block the carb. If I use a pipe that runs down the side my pedals are in the way.
Any ideas ?
Want to reply to this thread?
