Re:Solo : new carb will not start
M-Tenn Aaron /
I am at a 96 jet right now but it has some bogging out at the top end and some in mid throttle as well. I think I am going to drop to a 94 or 92 jet. It seemed to have the best performance around 92-94 jetting.
As far as the temp solution, I used a piece of rubber tubing from the stock airbox to slide over the stock intake with about 2 wraps of electrical tape over the tubing for a shim. This is a temp mod only ! I am not going to leave it like this, but until I can get a custom intake cast it will have to do.
I tried to take pics but they will just not turn out right.
If you have the stock airbox for a Solo Odyssey there should be a clear tube on it that goes up through the frame to keep the air flow away from the dirt on the road. The side that is connected to the airbox will fit pretty nice as a temp shim for a 15mm bing with a little electrical tape. This gave me an instant 10mph boost with the Puch 15mm bing and the Puch high flow air filter. It sounds wicked too!!! I love it. I can't wait until I tuni it in perfect. I think I can hit 40-45 no problem with an intake and a pipe.
  new carb will not startTopic by: M-Tenn Aaron M-Tenn Aaron 02/27/10 02:21PM
  Re: new carb will not startRe: derek derek 02/27/10 02:54PM
  Re: new carb will not startRe: derek derek 02/27/10 02:55PM
  Re: new carb will not startRe: mike mike 02/27/10 04:04PM
  Re: new carb will not startRe: Sunset Paul Sunset Paul 02/27/10 04:09PM
  Re: new carb will not startRe: Fish tits Krauthamer Fish tits Krauthamer 02/27/10 05:15PM
  Re: new carb will not startRe: clay clay 02/27/10 05:27PM
  Re: new carb will not startRe: m6onz5a m6onz5a 02/27/10 07:20PM
  Re: new carb will not startRe: M-Tenn Aaron M-Tenn Aaron 02/27/10 10:21PM
  Re: new carb will not startRe: M-Tenn Aaron M-Tenn Aaron 02/27/10 11:01PM
  Re: new carb will not startRe: Fish tits Krauthamer Fish tits Krauthamer 02/27/10 11:53PM
  Re: new carb will not startRe: M-Tenn Aaron M-Tenn Aaron 02/28/10 12:18AM
  Re: new carb will not startRe: Britchez Britchez 02/28/10 12:35AM
  Re: new carb will not startRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 02/28/10 06:32AM
  Re: new carb will not startRe: zeke zeke 02/28/10 07:43AM
  Re:Solo : new carb will not startRe: M-Tenn Aaron M-Tenn Aaron 02/28/10 11:45AM
  Re:Solo : new carb will not startRe: Britchez Britchez 02/28/10 11:50AM
  Re:Solo : new carb will not startRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 02/28/10 12:34PM
  Re:Solo : new carb will not startRe: M-Tenn Aaron M-Tenn Aaron 02/28/10 01:37PM
  Re:Solo : new carb will not startRe: andrewhed andrewhed 02/28/10 09:56PM
  Re:Solo : new carb will not startRe: M-Tenn Aaron M-Tenn Aaron 02/28/10 11:54PM
  Re:Solo : new carb will not startRe: [[ Linda ]] [[ Linda ]] 03/01/10 01:12AM
  Re:Solo : new carb will not startRe: derek derek 03/01/10 01:12AM
  Re:Solo : new carb will not startRe: M-Tenn Aaron M-Tenn Aaron 03/01/10 01:42AM
  Re: new carb will not startRe: M-Tenn Aaron M-Tenn Aaron 03/02/10 11:51AM
Want to reply to this thread?
