Re: cleaning up new kit
Rob @t ATTN! Burrito /
the chamfer should be about 1/2 mm in length from flat surface to surface on all your ports, as much of a radius as possible. the point is to make the cylinder port surfaces (lines) straight, like they intended, not jagged. (unless doing eyebrows or other fun stuff) think smooth, clean lines and if it's sharp running your finger of the port, then a ring is more likely to catch.
i'll also agree that bridge should be fine since it still has a solid MM left unmarred, at least chamfer it. if it makes you uneasy definitely grind it into a straight skinny bridge to look more like || than |\ and it will still serve its purpose. definitely one of the uglier castings ive seen!
  cleaning up new kitTopic by: derek derek 02/24/10 10:46PM
  Re: cleaning up new kitRe: derek derek 02/24/10 10:47PM
  Re: cleaning up new kitRe: Name Removed Name Removed 02/24/10 10:58PM
  Re: cleaning up new kitRe: derek derek 02/24/10 11:02PM
  Re: cleaning up new kitRe: R G R G 02/24/10 11:09PM
  Re: cleaning up new kitRe: spencer spencer 02/24/10 11:22PM
  Re: cleaning up new kitRe: spencer spencer 02/24/10 11:23PM
  Re: cleaning up new kitRe: † CH∆D † † CH∆D † 02/25/10 12:23AM
  Re: cleaning up new kitRe: derek derek 02/25/10 12:56AM
  Re: cleaning up new kitRe: the worst terry the worst terry 02/25/10 01:00AM
  Re: cleaning up new kitRe: derek derek 02/25/10 01:09AM
  Re: cleaning up new kitRe: the worst terry the worst terry 02/25/10 01:15AM
  Re: cleaning up new kitRe: the worst terry the worst terry 02/25/10 01:19AM
  Re: cleaning up new kitRe: derek derek 02/25/10 01:36AM
  Re: cleaning up new kitRe: the worst terry the worst terry 02/25/10 01:39AM
  Re: cleaning up new kitRe: derek derek 02/25/10 01:45AM
  Re: cleaning up new kitRe: spencer spencer 02/25/10 01:54AM
  Re: cleaning up new kitRe: the worst terry the worst terry 02/25/10 02:10AM
  Re: cleaning up new kitRe: the worst terry the worst terry 02/25/10 02:12AM
  Re: cleaning up new kitRe: Mo Peds Mo Peds 02/25/10 10:17AM
  Re: cleaning up new kitRe: Mo Peds Mo Peds 02/25/10 10:22AM
  Re: cleaning up new kitRe: Tom STL Tom STL 02/25/10 03:51AM
  Re: cleaning up new kitRe: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/25/10 10:26AM
  Re: cleaning up new kitRe: Mo Peds Mo Peds 02/25/10 10:44AM
  Re: cleaning up new kitRe: ffreddie ffreddie 02/25/10 10:56AM
  Re: cleaning up new kitRe: Mo Peds Mo Peds 02/25/10 10:45AM
  Re: cleaning up new kitRe: dean playing god on rafter's account dean playing god on rafter's account 02/26/10 10:03PM
  Re: cleaning up new kitRe: Mo Peds Mo Peds 02/27/10 12:21AM
  Re: cleaning up new kitRe: derek derek 02/27/10 12:03AM
  Re: cleaning up new kitRe: Mo Peds Mo Peds 02/27/10 12:18AM
  Re: cleaning up new kitRe: mattology - mattology - 02/27/10 12:19AM
  Re: cleaning up new kitRe: dean playing god on rafter's account dean playing god on rafter's account 02/27/10 12:27AM
  Re: cleaning up new kitRe: Mo Peds Mo Peds 02/27/10 12:33AM
  Re: cleaning up new kitRe: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 02/27/10 11:16AM
  Re: cleaning up new kitRe: derek derek 02/27/10 03:00PM
  Re: cleaning up new kitRe: dean playing god on rafter's account dean playing god on rafter's account 02/27/10 04:12PM
  Re: cleaning up new kitRe: Sunset Paul Sunset Paul 02/27/10 04:58PM
  Re: cleaning up new kitRe: Mo Peds Mo Peds 02/27/10 05:55PM
  Re: cleaning up new kitRe: adam12 adam12 02/27/10 11:06PM
  Re: cleaning up new kitRe: derek derek 02/27/10 10:35PM
  Re: cleaning up new kitRe: dean playing god on rafter's account dean playing god on rafter's account 02/27/10 10:44PM
  Re: cleaning up new kitRe: derek derek 02/27/10 11:26PM
Click here to login.
