Re: A35 conrod on A3?
[[ Linda ]] /
The only reason you can't put a Puch/A35 kit on an A3 is because the small end bushing on the A3 has a 10mm ID, and the Puch/A35 kits have a 12mm ID small end bushing. However, the OD on the Puch and A3 bushings are the same, so if you can press out the old 10mm A3 bushing, you can press in a new 12mm ID Puch bushing, and voila! Time to install a Puch/A35 kit.
Want to reply to this thread?
