Re: Intake solution for morini...fail? Win?
Organ Robbin' /
Well the case inducted motors have a large area that would need to be filled, you effectively added lots of crank case volume by going to the piston port kit. Just blocking the reed intake off and not filling that dead space limits the motor. Maybe you filled that space but you're still limiting what the motor can do by blocking that off. I'm pretty sure the crank is different too.
I'm pretty sure I have a 4 pedal setup in my garage somewhere. It will be hidden under the rizatto intake, which at the moment hasnt been mounted but it looks like it will work quite well with the 19mm dell on my pacer.
  Intake solution for morini...fail? Win?Topic by: mike mike 02/23/10 10:10PM
  Re: Intake solution for morini...fail? Win?Re: clay clay 02/24/10 12:54AM
  Re: Intake solution for morini...fail? Win?Re: mike Thomas mike Thomas 02/24/10 01:07AM
  Re: Intake solution for morini...fail? Win?Re: mike Thomas mike Thomas 02/24/10 12:22PM
  Re: Intake solution for morini...fail? Win?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/24/10 12:27PM
  Re: Intake solution for morini...fail? Win?Re: Mo Peds Mo Peds 02/24/10 01:59PM
  Re: Intake solution for morini...fail? Win?Re: Mordecai Mordecai 02/24/10 02:05PM
  Re: Intake solution for morini...fail? Win?Re: Tom STL Tom STL 02/24/10 02:25PM
  Re: Intake solution for morini...fail? Win?Re: Organ Robbin' Organ Robbin' 02/24/10 04:03PM
  Re: Intake solution for morini...fail? Win?Re: Mordecai Mordecai 02/24/10 04:43PM
  Re: Intake solution for morini...fail? Win?Re: Chelsea Chelsea 02/24/10 10:23PM
  Re: Intake solution for morini...fail? Win?Re: Organ Robbin' Organ Robbin' 02/25/10 10:51AM
  Re: Intake solution for morini...fail? Win?Re: miket miket 02/25/10 05:37PM
  Re: Intake solution for morini...fail? Win?Re: Orphan Frick Orphan Frick 02/25/10 05:26PM
  Re: Intake solution for morini...fail? Win?Re: mike mike 02/25/10 07:15PM
  Re: Intake solution for morini...fail? Win?Re: N@sty P N@sty P 02/25/10 05:32PM
  Re: Intake solution for morini...fail? Win?Re: christopher k christopher k 02/25/10 10:03PM
Want to reply to this thread?
