Re: 30mm header?
spencer /
hey ive got that same kit, pipe, carb setup on an e50 bottom end with korado cdi, do it
this was just a early mock up and i havnt taken another picture yet, but the pipe doesnt kick up as much as it does in this picture. the end of the silencer sits right above mid wheel now instead of up high. i only have about 2 inches of clearance between the header and road on the n frame but i imagine with the way the tomos top end is angled up you will get a bit more clearance.
  30mm header?Topic by: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 09:55AM
  Re: 30mm header?Re: zeke zeke 02/23/10 10:05AM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 10:16AM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 10:27AM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 10:37AM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 10:40AM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 11:04AM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 11:13AM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 11:16AM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 11:37AM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 11:50AM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 12:21PM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 12:26PM
  Re: 30mm header?Re: spencer spencer 02/23/10 11:54AM
  Re: 30mm header?Re: spencer spencer 02/23/10 12:35PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 12:41PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 12:45PM
  Re: 30mm header?Re: rofman rofman 02/23/10 12:55PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 01:07PM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 01:48PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 02:29PM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 03:01PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 03:09PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/21/10 02:40PM
  Re: 30mm header?Re: The real rafter The real rafter 03/21/10 06:26PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/21/10 07:04PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/21/10 10:17PM
  Re: 30mm header?Re: Daes Daes 03/24/10 02:41AM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/24/10 12:54PM
  Re: 30mm header?Re: xamboozi xamboozi 03/25/10 01:01PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/25/10 03:23PM
Want to reply to this thread?
