Re: 30mm header?
Cold Trailer GARzan Justin /
"Hmm no clue justin, I run one on a safari, pretty loud."
Wat? Dude, he never mentioned a Hurricane, nor asked about its header diameter, nor pointed out any correlation between header diameter and loudness of the pipe. This is why I'm confused.
"brand new clutches courtesy of home depot ;-)"
Go on...?
"stock CDI"
Grab a new box? Do those have a single pulse out from the stator? I'm really unfamiliar with Tomos ignition systems. In any case, you definitely won't reach that cylinder/pipe's potential if your ignition is cutting you out at 9k, or even 10k. That kit wants to rev. Stay away from the Treats 12v points stator; I've got one and it worked for about two months, after that it's been nothing but trouble. I'd say grab the points from an A35 and drop the front gear a few teeth so they'll fit. With as high as that setup will rev, you won't need super high gearing to still go fast.
I'm excited for yous.
  30mm header?Topic by: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 09:55AM
  Re: 30mm header?Re: zeke zeke 02/23/10 10:05AM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 10:16AM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 10:27AM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 10:37AM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 10:40AM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 11:04AM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 11:13AM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 11:16AM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 11:37AM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 11:50AM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 12:21PM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 12:26PM
  Re: 30mm header?Re: spencer spencer 02/23/10 11:54AM
  Re: 30mm header?Re: spencer spencer 02/23/10 12:35PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 12:41PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 12:45PM
  Re: 30mm header?Re: rofman rofman 02/23/10 12:55PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 01:07PM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 01:48PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 02:29PM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 03:01PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 03:09PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/21/10 02:40PM
  Re: 30mm header?Re: The real rafter The real rafter 03/21/10 06:26PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/21/10 07:04PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/21/10 10:17PM
  Re: 30mm header?Re: Daes Daes 03/24/10 02:41AM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/24/10 12:54PM
  Re: 30mm header?Re: xamboozi xamboozi 03/25/10 01:01PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/25/10 03:23PM
Click here to login.
