Re: 30mm header?
Cold Trailer GARzan Justin /
Going on an A55 bottom end, the port will be almost flat because that cylinder angles up, but you'll need to figure out a way to get that pipe around the case.
That header isn't too big. FWIW, the Simonini has a 30mm header too. Run the 24mm Mikuni. You won't affect the port timing, as long as you don't alter the port window in the cylinder. If you just match the outside of the port to the header, you'll be fine.
  30mm header?Topic by: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 09:55AM
  Re: 30mm header?Re: zeke zeke 02/23/10 10:05AM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 10:16AM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 10:27AM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 10:37AM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 10:40AM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 11:04AM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 11:13AM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 11:16AM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 11:37AM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 11:50AM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 12:21PM
  Re: 30mm header?Re: Mo Peds Mo Peds 02/23/10 12:26PM
  Re: 30mm header?Re: spencer spencer 02/23/10 11:54AM
  Re: 30mm header?Re: spencer spencer 02/23/10 12:35PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 12:41PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 12:45PM
  Re: 30mm header?Re: rofman rofman 02/23/10 12:55PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 01:07PM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 01:48PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 02:29PM
  Re: 30mm header?Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 03:01PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 02/23/10 03:09PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/21/10 02:40PM
  Re: 30mm header?Re: The real rafter The real rafter 03/21/10 06:26PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/21/10 07:04PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/21/10 10:17PM
  Re: 30mm header?Re: Daes Daes 03/24/10 02:41AM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/24/10 12:54PM
  Re: 30mm header?Re: xamboozi xamboozi 03/25/10 01:01PM
  Re: 30mm header?Re: Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ 03/25/10 03:23PM
Click here to login.
