Re: new kit, compression to high?
ZEROS Brian /
What kind of spark plug did you use when you changed it??? If you use the wrong plug, it will actually hit the piston and make you think your engine is locked or too high of compression! The threaded parts on the sparkplugs vary with different numbered plugs!!
Want to reply to this thread?
