I had a similar issue with a new kit. I was having to pull so hard on the clutch to get it to turn the engine that I wore a deep irregular channel in my starter plate and I had to replace it. It's the new rings. They will wear down a bit and the compression should drop enough to make it not so difficult to start. Shouldn't take long. At least that's what happened with mine. Good luck.
Re: new kit, compression to high?
Subject | Written By | Posted |
new kit, compression to high?Topic by: dave | dave | 02/20/10 04:12PM |
Re: new kit, compression to high?Re: Gnihton orez | Gnihton orez | 02/20/10 04:23PM |
Re: new kit, compression to high?Re: dave | dave | 02/20/10 04:29PM |
Re: new kit, compression to high?Re: dave | dave | 02/20/10 06:24PM |
Re: new kit, compression to high?Re: Ty Koon | Ty Koon | 02/20/10 09:44PM |
Re: new kit, compression to high?Re: ZEROS Brian | ZEROS Brian | 02/20/10 09:50PM |
Re: new kit, compression to high?Re: Tom STL | Tom STL | 02/21/10 02:09AM |
Want to reply to this thread?
