Re: gasket maker
Andy /
Everyone has their own way, but things to remember would be.
- I always use an actual base gasket that's made for the cylinder, particular for timing. If it's stock timing, I use 'stock' gasket'
- I sand down top of cylinder and bottom of head, so they are exactly flat, then I use only red RTV, liberally, leaving enough space so when it's compressed, it won't go into the cylinder. I apply it evenly and let it sit for about one minute, then put the two pieces together, torque it down all the way, but not tightly (don't want it all to squeeze out). But the amount that does squeeze out is good, because it provides further insurance from leaks.
- Copper head gaskets are good because they squish, but again RTV is fine too.
- I use red RTV for the intake gasket.
The most important thing when using RTV is make sure you get the right heat resistance.
  Sealant advice.Topic by: Nash . Nash . 02/19/10 02:21AM
  Re: Sealant advice.Re: mattology - mattology - 02/19/10 02:26AM
  Re: Sealant advice.Re: Nash . Nash . 02/19/10 02:29AM
  Re: Sealant advice.Re: Nash . Nash . 02/19/10 02:31AM
  Re: Sealant advice.Re: Saabsonettguy . Saabsonettguy . 02/19/10 02:40AM
  Re: Sealant advice.Re: durepo durepo 02/19/10 02:47AM
  Re: Sealant advice.Re: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 02/19/10 02:53AM
  Re: Sealant advice.Re: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 02/19/10 02:55AM
  Re: Sealant advice.Re: mit mortso mit mortso 02/19/10 03:44AM
  Re: Sealant advice.Re: pullstart pullstart 02/19/10 04:27AM
  Re: Sealant advice.Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/19/10 04:49AM
  Re: Sealant advice.Re: Sunset Paul Sunset Paul 02/19/10 05:05AM
  gasket makerRe: Jon Jon 02/19/10 05:18AM
  Re: gasket makerRe: mattology - mattology - 02/19/10 11:17AM
  Re: gasket makerRe: Tom STL Tom STL 02/19/10 11:59AM
  Re: gasket makerRe: Tom STL Tom STL 02/19/10 12:25PM
  Re: gasket makerRe: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/19/10 12:52PM
  Re: gasket makerRe: Flagrant - Flagrant - 02/19/10 01:49PM
  Re: gasket makerRe: —— ¢hief —— —— ¢hief —— 02/19/10 01:59PM
  Re: gasket makerRe: Josh Schutz Josh Schutz 02/19/10 02:00PM
  Re: gasket makerRe: —— ¢hief —— —— ¢hief —— 02/19/10 02:03PM
  Re: gasket makerRe: —— ¢hief —— —— ¢hief —— 02/19/10 02:07PM
  Re: gasket makerRe: Andy Andy 02/19/10 02:13PM
  Re: gasket makerRe: Nash . Nash . 02/19/10 02:38PM
  Re: gasket makerRe: Polini Blasty Gnar Gnar Polini Blasty Gnar Gnar 02/20/10 12:05AM
  Re: gasket makerRe: Emperor Swagustus Emperor Swagustus 02/20/10 12:32AM
  Re: gasket makerRe: mit mortso mit mortso 02/20/10 03:51AM
  Re: gasket makerRe: John Joedicke John Joedicke 02/20/10 12:45PM
  Re: gasket makerRe: Josh Schutz Josh Schutz 02/20/10 02:22PM
  Re: gasket makerRe: Jon Jon 02/21/10 01:40AM
Click here to login.
