Re: gasket maker
Cold Trailer GARzan Justin /
hahahahaha
I love everyone.
Nash, my case sealant (Permatex Motoseal, grey tube) is my do-all gasket sealer. For base gaskets, I just slobber a little bit on each side, a nice thin layer, then stick it on. I'd have to say it works, I didn't have to add any material on my case matched MK80 large port, no leaks. I hand make all of my gaskets, I don't run head gaskets, except on the Metra, because it's such a pain in the ass to start without one, too much compression. I did mill the mating surfaces on that DMP, that really helped it seal. Also, I use castle nuts instead of regular nuts, I can get a lot more torque with them and don't strip my cylinder studs.
  Sealant advice.Topic by: Nash . Nash . 02/19/10 02:21AM
  Re: Sealant advice.Re: mattology - mattology - 02/19/10 02:26AM
  Re: Sealant advice.Re: Nash . Nash . 02/19/10 02:29AM
  Re: Sealant advice.Re: Nash . Nash . 02/19/10 02:31AM
  Re: Sealant advice.Re: Saabsonettguy . Saabsonettguy . 02/19/10 02:40AM
  Re: Sealant advice.Re: durepo durepo 02/19/10 02:47AM
  Re: Sealant advice.Re: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 02/19/10 02:53AM
  Re: Sealant advice.Re: Rob @t ATTN! Burrito Rob @t ATTN! Burrito 02/19/10 02:55AM
  Re: Sealant advice.Re: mit mortso mit mortso 02/19/10 03:44AM
  Re: Sealant advice.Re: pullstart pullstart 02/19/10 04:27AM
  Re: Sealant advice.Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/19/10 04:49AM
  Re: Sealant advice.Re: Sunset Paul Sunset Paul 02/19/10 05:05AM
  gasket makerRe: Jon Jon 02/19/10 05:18AM
  Re: gasket makerRe: mattology - mattology - 02/19/10 11:17AM
  Re: gasket makerRe: Tom STL Tom STL 02/19/10 11:59AM
  Re: gasket makerRe: Tom STL Tom STL 02/19/10 12:25PM
  Re: gasket makerRe: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/19/10 12:52PM
  Re: gasket makerRe: Flagrant - Flagrant - 02/19/10 01:49PM
  Re: gasket makerRe: —— ¢hief —— —— ¢hief —— 02/19/10 01:59PM
  Re: gasket makerRe: Josh Schutz Josh Schutz 02/19/10 02:00PM
  Re: gasket makerRe: —— ¢hief —— —— ¢hief —— 02/19/10 02:03PM
  Re: gasket makerRe: —— ¢hief —— —— ¢hief —— 02/19/10 02:07PM
  Re: gasket makerRe: Andy Andy 02/19/10 02:13PM
  Re: gasket makerRe: Nash . Nash . 02/19/10 02:38PM
  Re: gasket makerRe: Polini Blasty Gnar Gnar Polini Blasty Gnar Gnar 02/20/10 12:05AM
  Re: gasket makerRe: Emperor Swagustus Emperor Swagustus 02/20/10 12:32AM
  Re: gasket makerRe: mit mortso mit mortso 02/20/10 03:51AM
  Re: gasket makerRe: John Joedicke John Joedicke 02/20/10 12:45PM
  Re: gasket makerRe: Josh Schutz Josh Schutz 02/20/10 02:22PM
  Re: gasket makerRe: Jon Jon 02/21/10 01:40AM
Click here to login.
