Re: brembo brake setup for a moped
Mike /
That bike abs is bogus, it's just a dampener in the hydraulic system that takes some of the pressure away from the caliper so you don't lock up your tire, it effectively reduces your brake performance. You'll have to squeeze the brakes harder and the brake lever feel will not be as predictable as without this "abs" junk.
Click here to login.
