Oring the head?
Rick /
You have to cut a groove in the head and set a stainless wire in with butt ends, like was stated above. I used to do this all the time for V-8 Blower applications. We used an .051 wire in a .049 groove, set about .035 deep if I remember correctly. We still used thick, solid copper gaskets (.100) in combination with the wire, but it wouldn't be needed for a moped.
A std head gasket with matched surfaces should be fine unless you got some crazy ass comp ratio and/or over/under torque the head. Use a good, clip-stop torque wrench and you shold be fine
You don't want to use rubber.
  Oring the head?Topic by: mike Thomas mike Thomas 02/18/10 01:01AM
  Re: Oring the head?Re: clay clay 02/18/10 01:16AM
  Re: Oring the head?Re: Flagrant - Flagrant - 02/18/10 02:05AM
  Re: Oring the head?Re: I.R.E. Rick I.R.E. Rick 02/18/10 02:15AM
  Re: Oring the head?Re: Flagrant - Flagrant - 02/18/10 02:28AM
  Re: Oring the head?Re: Get Blatzed Get Blatzed 02/18/10 04:31AM
  Re: Oring the head?Re: mike mike 02/18/10 12:17PM
  Re: Oring the head?Re: ~ DeeZy ~ DeeZy 02/18/10 12:48PM
  Re: Oring the head?Re: Mike Mike 02/18/10 01:48PM
  Re: Oring the head?Re: Kelin Kelin 02/18/10 01:51PM
  Oring the head?Re: Rick Rick 02/18/10 02:09PM
  Re: Oring the head?Re: Not Tate Not Tate 02/18/10 03:00PM
  Re: Oring the head?Re: Bret Hoffman Bret Hoffman 02/18/10 03:00PM
  Re: Oring the head?Re: ovc ovc 02/18/10 03:48PM
  Re: Oring the head?Re: fishstics fishstics 02/18/10 05:08PM
  Re: Oring the head?Re: clay clay 02/18/10 06:11PM
  Re: Oring the head?Re: mike mike 02/18/10 06:42PM
  Re: Oring the head?Re: Mo Peds Mo Peds 02/18/10 06:49PM
  Re: Oring the head?Re: Flagrant - Flagrant - 02/18/10 07:52PM
  Re: Oring the head?Re: Flagrant - Flagrant - 02/18/10 07:53PM
  Re: Oring the head?Re: Mo Peds Mo Peds 02/18/10 08:02PM
  Re: Oring the head?Re: macelius-san macelius-san 02/18/10 08:41PM
  Re: Oring the head?Re: mike Thomas mike Thomas 02/20/10 01:29PM
  Re: Oring the head?Re: naz. naz. 02/20/10 01:41PM
  Re: Oring the head?Re: Andy Haldeman Andy Haldeman 02/21/10 03:34AM
  Re: Oring the head?Re: aceface aceface 02/21/10 07:12AM
  Re: Oring the head?Re: FormulaB FormulaB 02/25/10 03:20PM
Click here to login.
