Re: Metrakit E50 flooding issue WTF
Jaykayoh /
Stock head would run fine, but there is no point that is not your problem. More compression means more efficient burning. You could need a hotter plug if you are running like a B9, but even then I doubt that would be your problem.
Are you running stock timing? Stock timing would make you act rich. However, in this case I doubt that is the problem, since it is not slightly off but way off.
I can only see it being two things:
1. You are jetted wrong. As the bike warms up it needs a leaner jet.(This is why bikes have chokes) Once warm the big is too rich and killing itself. What your describing could be this. The opposite could be true. You could be getting and air leak when the bike heats up and expands which is causing a lean state, though I doubt it.
2. You do not have good spark. I know you just replaced everything and claim that it is all good. But typically when a condenser goes bad, it runs great at first and then after about 5 minutes the spark gets worse and worse till it does not work. Once the condense cools again, it sparks fine. I know you said that your condenser is new, but sometimes they are bad from the start.
  Metrakit E50 flooding issue WTFTopic by: Nasty Nasty 02/17/10 05:33PM
  Re: Metrakit E50 flooding issue WTFRe: bully -+:| bully -+:| 02/17/10 05:35PM
  Re: Metrakit E50 flooding issue WTFRe: Nasty Nasty 02/17/10 05:44PM
  Re: Metrakit E50 flooding issue WTFRe: Saabsonettguy . Saabsonettguy . 02/17/10 06:29PM
  Re: Metrakit E50 flooding issue WTFRe: andrewhed andrewhed 02/17/10 07:51PM
  Re: Metrakit E50 flooding issue WTFRe: Nasty Nasty 02/18/10 01:10AM
  Re: Metrakit E50 flooding issue WTFRe: Tommy Too Tall Tommy Too Tall 02/18/10 01:41PM
  Re: Metrakit E50 flooding issue WTFRe: neezy neezy 02/18/10 02:46PM
  Re: Metrakit E50 flooding issue WTFRe: nasty nasty 02/19/10 06:08PM
  Re: Metrakit E50 flooding issue WTFRe: bully -+:| bully -+:| 02/19/10 06:37PM
  Re: Metrakit E50 flooding issue WTFRe: Jesse Stephenson Jesse Stephenson 02/19/10 08:13PM
  Re: Metrakit E50 flooding issue WTFRe: Josh B. Josh B. 02/20/10 12:22AM
  Re: Metrakit E50 flooding issue WTFRe: Nasty Nasty 02/20/10 06:22PM
  Re: Metrakit E50 flooding issue WTFRe: nasty nasty 02/22/10 05:42PM
  Re: Metrakit E50 flooding issue WTFRe: Burntout Swoop Burntout Swoop 02/26/10 03:29PM
  Re: Metrakit E50 flooding issue WTFRe: Fish tits Krauthamer Fish tits Krauthamer 02/22/10 06:00PM
  Re: Metrakit E50 flooding issue WTFRe: Jaykayoh Jaykayoh 02/22/10 06:08PM
  Re: Metrakit E50 flooding issue WTFRe: Kansas John Kansas John 02/22/10 07:31PM
  Re: Metrakit E50 flooding issue WTFRe: Nash . Nash . 02/23/10 02:18AM
  Re: Metrakit E50 flooding issue WTFRe: Nasty Nasty 02/23/10 10:29AM
  Re: Metrakit E50 flooding issue WTFRe: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/23/10 10:35AM
  Re: Metrakit E50 flooding issue WTFRe: andrewhed andrewhed 02/24/10 12:41PM
  Re: Metrakit E50 flooding issue WTFRe: Serious Business Serious Business 02/24/10 12:44PM
  Re: Metrakit E50 flooding issue WTFRe: individu individu 02/25/10 04:29PM
  Re: Metrakit E50 flooding issue WTFRe: Flagrant - Flagrant - 02/25/10 05:03PM
  Re: Metrakit E50 flooding issue WTFRe: Burntout Swoop Burntout Swoop 02/26/10 03:31PM
Want to reply to this thread?
